June 30, 2006, 21:30 |
Fatal overflow in multiphase
When I use single phase in simulating tank filling,it converge well.But when I switch to multiphase,error appears: | ERROR #004100018 has occurred in subroutine FINMES. | | Message:| | Fatal overflow in linear solver.
Can any body tell me why? |
July 1, 2006, 03:54 |
Re: Fatal overflow in multiphase
The convergence fairy is stubborn in multiphase flows. Could be any of a myriad reasons.
July 3, 2006, 04:30 |
You can try to reduce your timestep. Sometimes, with two fluids, I've worked with 1e-5. When the flow will be more stable, you can use a bigger timestep. However, it's better to obtain an initial value file, for example using first a 'zero equation' turbolence model, which is very robust.
Solution variables goes outside upper limit -how to localize fatal overflow occurance | Dimone | CFX | 2 | January 21, 2011 06:35 |
desperate Fatal overflow in linear solver - transient | kingjewel1 | CFX | 9 | January 5, 2010 13:53 |
Fatal Overflow when using RNG k-e | Pascal | CFX | 2 | February 5, 2008 16:41 |
FINMES Error - Fatal Overflow in linear solver | Jacob | CFX | 0 | January 10, 2007 08:43 |
error while compiling the USER Sub routine | CFD user | CFX | 3 | November 25, 2002 15:16 |
