CFX mesh import from ICEM (Windows)
Old   June 30, 2006, 19:38
Default CFX mesh import from ICEM (Windows)
Andrew
Here is a newbie question if there ever was one. I have generated a mesh in ICEM but can't seem to import it to CFX-Pre. Both importing the .uns file as an "Ansys mesh", and importing the .in file (the Ansys simulation input file) as an "ICEM mesh" give errors. I am not using the Workspace. Also, the .in file is more than just the mesh, but I see no way to feed it to CFX. Can someone clarify this for me?
Old   June 30, 2006, 20:17
Default Re: CFX mesh import from ICEM (Windows)
Joe
ICEM in CFX mode generates a .msh file which is imported into pre with the ICEM option.
Old   July 1, 2006, 01:00
Andrew
Thanks for your response, Joe. I am not sure what you mean by CFX mode, but when I export the mesh from ICEM to "Ansys", I get a .in file (which cannot be read by CFX. The same happens when I do Solve Options/Write-View Input File, targetting the Ansys solver. I have never seen an .msh file output. I am completely confused?
Old   July 1, 2006, 04:51
Joe
Do the CFX specific tutorials in the ICEM manual
Old   July 2, 2006, 04:03
Chebeba
Make shure you select CFX as solver under the output tab, then export. This will produce a file with .cfx5 extension.
In CFX-Pre, go to mesh import and select "ICEM CFD" as source, then pick the .cfx5 file.
Done.
Old   July 2, 2006, 09:51
imad
if you have cfx 10 you must use workbench to export to cfx
Old   July 6, 2006, 09:41
Patrick
The Ansys mesh is related to the mechanical calculations. For CFX you have following possibilities: .msh, .cfx5 and .gtm.
Best way: Start up ICEMCFD, follow the menu Settings->Product and set the radio button to "Ansys ICEM CFD - CFX Version".
Then you have to restart ICEMCFD. Afterwards the Output register will have a new design and the button "Output to CFX" will automatically procduce a .msh file. These files can be imported in CFX as an ICEM file.
Good luck
Old   July 6, 2006, 12:39
myron
Some basic questions:
Which version of ICEM are you using? Which version of CFX are you using?
What do you have in your ICEM license file? OUTPUT, AIOUTCFD, AIOUTCFX - any of these?
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 07:20
[ICEM] trouble with mesh quality from ICEM in CFX Solver escher25 ANSYS Meshing & Geometry 0 February 28, 2011 08:38
Error when creating ICEM mesh output to CFX Zoran CFX 4 November 9, 2010 06:13
how to export icem mesh to cfx? Michael CFX 1 May 3, 2008 14:35
Import a rectangular domain into CFX 5.7 from ICEM SKLam CFX 9 March 8, 2006 01:47
