head of an axial turbine in two-phased analysis |
June 8, 2020, 05:40 |
amirbhr
Rep Power: 7 |
Hello all!
I am simulating an axial water turbine within an open channel. The simulation has been done using a free surface method for two phases water and air. In cfd-post, I have a problem with the efficiency computation while calculating the net hydraulic head. I cannot find any way to calculate the efficiency directly and I have to find the head to evaluate the efficiency. Would anyone help me in this regard? |
June 16, 2020, 13:18 |
need for help
amirbhr
Rep Power: 7 |
any help would be greatly appreciated
June 16, 2020, 13:51 |
Rep Power: 33 |
Are you using the existing macro in CFD-Post for efficiency? If yes, do those macros work for multiphase simulations?
What is the formula you expect should be used for those calculations? perhaps with such information, someone in the forum can help realize it via expressions.
June 24, 2020, 11:50 |
amirbhr
Rep Power: 7 |
Thanks, Opaque!
Yes, I used Macro icon, but I encountered the error "no total pressure in stn. frame". Besides, I tried to use the formula T(torque on shaft) * omega / (rho * g * Q(mass flow rate) * H (net head over the axial turbine) ). In this stage, the calculation of the hydraulic head (H) is my question. |
efficiency, free surface, hydraulic head, water turbine |
regarding fluent setup for wind turbine analysis | er_ijaz | FLUENT | 0 | May 1, 2013 05:55 |
Cyclic Symmetry - transient- axial turbine case. | Gowrav | Main CFD Forum | 1 | April 13, 2013 09:15 |
Turbine Analysis - Alternate Rotation Model and Meshing Problems | sean89dunn | CFX | 2 | March 23, 2013 23:27 |
Analysis of Wind turbine blade ( 3D aerofoil) by Ansys 12 | rsskarthikeyan | FLUENT | 5 | October 13, 2012 23:29 |
CFX Analysis of a wind turbine | Bournegenius | CFX | 16 | August 20, 2012 20:16 |
