June 23, 2006, 00:59 |
How to learn cfx ?
Hi all,
I want to learn cfx in deep.But I can only learn from the Help.There is no efficient transient simulation tutorials ,that I need most.What should I do next? Thank you in advance for any suggestion. Regards,James |
June 23, 2006, 08:07 |
Re: How to learn cfx ?
hi, tutorials are available. you can learn a lot from them. Infact I did like that only. best wishes
August 16, 2010, 06:20 |
Learning CFX
Mahdi Shahverdi
Rep Power: 16 |
I am completely new in CFX. As I undedestood, this is completely different with fluent and ansys.
My understanding is that the geometry and mesh should be prepared in other softwares. Am I right? How can I use the Ansys model and mesh in CFX? Please inform me if you have any recomendation. (m.shahverdi@gmail.com) |
August 16, 2010, 06:28 |
Pavelistyj
Rep Power: 16 |
Hi ,
I'm also new to CFX and I have a lot of troubles to get started ! So if you find any helpfull tutorials/manuals please share it with me . Mahdi , You may create the geometry and the mesh using DesignModeler and DesignMesh that are available on ANSYS Workbench . You can also create geometry and the mesh using GAMBIT , insert it into FLUENT and create CASE FILE . Then insert the FLUENT CASE file into the CFX . Pavelko . Last edited by Pavelko; August 18, 2010 at 05:26. |
August 20, 2010, 13:44 |
Rep Power: 17 |
There are good tutorials in the software. Also, there are tutorials in the Program Files. For me, the directory path is
C:\Program Files\ANSYS Inc\v121\commonfiles\help\en-us\CFX\help\pdf I would suggest googling "CFX tutorial" and "DesignModeler tutorial." There are even hits for youtube but I have not checked them out. CFD is hard core stuff and requires quite the learning curve. Good luck! |
August 21, 2010, 05:21 |
Rep Power: 16 |
hi
I think the best reference to learn a software is its help along with tutorials. to do a good simulation using CFX, I think you shoud study modelling guide along with theroy guide, because it is important to be inform of different models that are available in CFX. And about mahdi's question, I use gambit to build and mesh the geometry. In this way, you should choose the generic solver in gambit, and export the file with a "*.neu" format. import the file in fluent, check the mesh, initialize it, and then export it to a "PATRAN neutral" platform. in cfx you should import the mesh from the "PATRAN neutral" option and with a ".neu" format. good luck |
August 21, 2010, 17:43 |
Joshua Counsil
Rep Power: 18 |
In addition to the CFX tutorials, which are very good and are included in the Help file, I'd recommend purchasing, downloading (if you or your school has a subscription to Springerlink, Knovel, etc.), or signing out a CFD theory textbook. CFD Online has a section with CFD book reviews [http://www.cfd-online.com/Books/ here]. Computational Methods for Fluid Dynamics (Ferziger & Péric) is my book of choice.
If you don't know the theory, you will be wasting your time and your results. I wasted almost an entire summer doing CFD simulations without knowing the theory very well. I like to read while my simulations are running. Don't make the same mistake I, and many others, made. |
August 23, 2010, 18:00 |
Help file is cool okay
but any samples ?! I think Samples + their pdf tutorials are the best sources to learn a CFD software like those are available for fluent !? |
August 23, 2010, 19:21 |
#9 |
Rep Power: 144 |
There are a lot of tutorials available on the ANSYS Customer web page on the ANSYS web site.
August 23, 2010, 19:41 |
#10 |
Joshua Counsil
Rep Power: 18 |
The examples are located in the Help file as well as on the ANSYS Customer Portal.
August 25, 2010, 12:18 |
#11 | |
You have to start Workbench, create your analysis(a list on the left side). use Design modeler to import geometry file(Parasolid, for example) use meshing to create mesh and use CFX-Pre to apply boundary conditions. |
ATTENTION! Reliability problems in CFX 5.7 | Joseph | CFX | 14 | April 20, 2010 16:45 |
heat generation in CFX | Ema | CFX | 4 | August 7, 2009 06:39 |
Electronics Enclosure Analysis with CFX | Simulation Engineer | CFX | 1 | April 22, 2009 12:08 |
CFX 10's solutions differ from CFX 5.7's | Atit Koonsrisuk | CFX | 4 | July 26, 2006 12:59 |
CFX 4.4 installation problem | Pandu Sattvika | CFX | 1 | December 1, 2001 05:07 |
