multi domain heat transfer prob
Old   June 22, 2006, 04:56
Default multi domain heat transfer prob
mohammed zubair
We are solving a multidomain heat transfer model to find out the heat transfer characteritics between hot fluid and a cold fluid.
our prob is that we have defined different materils for each domain but CFX is taking into considration only one material. i.e if we have defined water as the material for cold domain and air as the material for hot domain, while defining physics it is taking into account only one material. if we take water first the same material is automatically taken by the hot domain as well.
any body can help solve the prob
Old   June 27, 2006, 10:30
Default Re: multi domain heat transfer prob
Mike
Set the environement variable:
CFX5_NO_CONSTANT_PHYSICS=T
Now when you run CFX-Pre it will not force the same fluids to be used in all domains. Mike
Heat transfer coefficient - what is waht Stan FLUENT 28 December 29, 2021 17:29
Heat Transfer in Porous Medium eryan STAR-CD 0 September 28, 2010 14:14
How can I increase Heat Transfer at Domain Interf? B.Simon CFX 3 October 28, 2008 19:53
Concentric tube heat exchanger (Air-Water) Young CFX 5 October 7, 2008 00:17
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 16:55
