How to control the Inlet block mesh in turbogrid
Old   June 21, 2006, 21:21
Default How to control the Inlet block mesh in turbogrid
Mickel
Hi everyone,
There is a long inlet domain in my turbomachiery created with Bladegen. As I kown, Turbogrid just mesh single blade passage of a turbomachinery.Then in the Turbogrid , the long inlet domain takes on a triangle shape because the hub curve superposes with the rotation axis in the inlet domain. My problem is that the long triangle inlet domain always has bad meshes such as zero minmum angle near the hub curve, 180 degree maximum angle near the hub curve and large volume ratio.
Had anyone entercoutered such mesh problem? If the long inlet domain cann't be shorten, how to control the mesh.
Any idea of you will be appreciated.
Thanks in advanced!
Mickel
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 09:54
Problems of running Oscillating plate tutorial vovogoal CFX 20 February 4, 2016 08:03
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 22:11
increasing mesh quality is leading to poor convergence tippo CFX 2 May 5, 2009 11:55
unstructured vs. structured grids Frank Muldoon Main CFD Forum 1 January 5, 1999 11:09
