transitional inlet boundary condition
Old   June 21, 2006, 09:38
Default transitional inlet boundary condition
kamp
Hi there,
I'd like to simulate a simplified propeller-wake entering an engine-inlet duct without having to model the propeller blade generating the wake. Therefore, as the propeller periodically interacts with the incomming flow, I intend to setup the inlet boundary condition of the duct in such a way as if the shadow of the blade passed the inlet-plane.
I planned to setup a profiled inlet b.c. which represents one blade wake (e.g. total pressure wake) and to apply it to the inlet in such a way that with each time step it is clockwisely moved a little bit (according to the speed of rotation of the blade). Doing so I hope to get the effect of a wake passing the inlet. I succeeded in applying a periodically changing inlet b.c. to the WHOLE inlet area via expressions. But what I want to do now is different as only the part of the inlet should be affected by the distortion which geometrically represents the extension of the blade (which is much narrower than the inlet is). Is there a way to achieve this (transitional applied profiled input) ?
Thank you in advance for any comment!
Markus
Old   June 21, 2006, 12:08
Default Re: transitional inlet boundary condition
Joe
You can specify inlet conditions of arbitrary complexity both spatially and temporaly via user CEL / Fortran etc.
ATTENTION! Reliability problems in CFX 5.7 Joseph CFX 14 April 20, 2010 16:45
How to use a solution as an inlet boundary condition in another problem in fluent geryes FLUENT 0 February 25, 2010 17:32
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 05:05
inlet and outlet boundary condition for turbomachinery solution siamak1424 OpenFOAM 2 August 15, 2009 12:14
Natural convection - Inlet boundary condition max91 CFX 1 July 29, 2008 21:28
