Convergence problems with SSG turbulence model
Old   June 19, 2006, 10:07
Default Convergence problems with SSG turbulence model
Ram
Hi Everyone,
I have to calculate swirling flow in a reactor. First i used k-e model and it converged well. As it is not accurate for swirling flows i tried to calculate with SSG turbulence model. I am getting convergence problems. I tried with very fine mesh, initial guess & interploation of k-e model solution, and different physical time scales, auto time scale etc but in vain.
I used same conditions as for K-e model. Do I need to specify any additional conditions for SSG model to get convergence?
Thank you.
Old   June 19, 2006, 11:08
Default Re: Convergence problems with SSG turbulence model
Joe
There is no magic bullet for getting SMC turbulence models to converge properly.
Try a straight run without restarting from a k-e initial guess and other similar experiments.
The convergence fairy often requires you make a concerted effort before she smiles and waves her wand.
multiphaseInterFoam for RAS turbulence model chiven OpenFOAM Bugs 8 December 6, 2017 03:08
Water subcooled boiling Attesz CFX 7 January 5, 2013 04:32
Problems with boundary conditions for a lowRekOmegaSST turbulence model cfdmarkus OpenFOAM Running, Solving & CFD 16 November 14, 2011 05:44
build your own turbulence model with buoyancy Thomas Baumann OpenFOAM 11 November 23, 2009 09:53
Turbulence model convergence problem Andrew CFX 7 August 17, 2008 20:35
