congence???
Old   June 13, 2006, 02:58
Default congence???
prayskyer
i did some a computation! i chose air(idea gas) as fluid, and reference pressure=14atm;energy model----total energy;k-e model;intial condition=automatic
BC:inlet---mass rate;total tempreture=1200K; outlet----reletive pressure=-600000Pa;
it never congence,but when i turn outlet's reletive pressure to 0Pa,it congence,it that 14atm have some problem?if not,where can i modify them?
how this could happen,and what can i do? thanks in advance!!!
Old   June 13, 2006, 03:53
Default Re: congence???
Fred
Do you mean convergence?
A negative pressure is not very well chosen because there is no negative pressure in the universe. Under domain you can set the reference pressure to 0 atm and then calculate or set every pressure as it is in real.
Old   June 13, 2006, 04:28
prayskyer
but 14atm-600000Pa=800000Pa,it's a positive value!
if i set 0 for reference pressure,then the outlet's pressure will really become negative value (0--600000Pa=-600000Pa)
Old   June 13, 2006, 16:15
Fred
Then set the outlet to 8 atm. Where is the problem?
Old   June 13, 2006, 21:50
prayskyer
haha,i found it!the inlet is subsonic,but outlet is supersonic,i set them wrong!
so this flow from subsonic area into supersonic area,is some suggestions i can concern?
thanks all of u
Old   June 13, 2006, 22:55
prayskyer
i am wrong again!it's still subsonic!
the problem still on!!!
Old   June 14, 2006, 07:45
Fred
YOu can try to change the outlet to an opening. This is more stable then a subsonic outlet.
Old   June 14, 2006, 08:28
prayskyer
i try!but it seems not that problem there!
seems that outlet's relative pressure -600000,
IN CFX,can i put negative value like -600000 there?
Old   June 14, 2006, 11:48
Fred
i dont see the benefit in doing this. why do you do this? why not 0atm and 8 atm?
Old   June 14, 2006, 21:08
prayskyer
0atm and 8atm can't congence either!
i try once! i don't know why?
how long can i solve this problem,help me!
thanks
Old   June 14, 2006, 21:12
  #11
prayskyer
could anyone help me!
prayskyer@yahoo.com.cn
this is my e-mail!i can send this to u!
thanks a lot!
turbine compt:why can't congence??? prayskyer CFX 1 June 12, 2006 03:09
