Shear strain rate insertion at Bingham plastic model
Old   May 12, 2020, 11:36
Default Shear strain rate insertion at Bingham plastic model
Ahammed Rubel
Ahammed Rubel is on a distinguished road
Dear Experts,
I want to simulate magneto-rheological fluid damper. Here I want to use default Bingham Plastic model at CFX. I have calculated Shear Stress for different current density by using APDL Electromagnetic .
Shear Stress average value [(Bmax+Bmin)/2] =3186.55 T. Should I put this value as yield stress?
For a specific shear stress how can I calculate Shear Strain Rate maximum and minimum value.
For Bingham Plastic model which data need to insert?
Ahammed Rubel is offline   Reply With Quote
Old   May 12, 2020, 13:44
Opaque will become famous soon enough
A Bingham fluid is defined by its Yield Stress and Viscosity Consistency (see ANSYS CFX documentation for details).
I understand a magneto-rheological fluid as fluid where its properties can be a function of magnetic field variables, say B or H. I would translate that as
Yield Stress = Function F (B or H, Temperature, etc)
Viscosity Consistency = Function G (B, or H, Temperature, etc)
The shear strain rate limits are to control the numerics of how the viscosity is treated in the equations, they are not a physical property of the material.
What are the F and G above? You should look for that information in the literature for that material.
Note: I do not answer CFD questions by PM. CFD questions should be posted on the forum.
Opaque is offline   Reply With Quote
[openSmoke] libOpenSMOKE Tobi OpenFOAM Community Contributions 562 January 25, 2023 10:21
Modeling viscosity. Shear strain=Shear rate? jpina FLUENT 3 January 28, 2022 06:37
How to define strain rate and shear rate magnitude in CFD-Post? khhan0543 Fluent UDF and Scheme Programming 3 January 13, 2017 15:38
Strain rate calculation for explicitly filtered constant smagorinsky model cfdmms Main CFD Forum 2 December 2, 2013 15:09
Flow of Bingham plastic model in Fluent 6.3 koti121 FLUENT 0 April 24, 2009 04:35
