ANSYS System coupling for the problem of pipe thermal expansion
Old   May 10, 2020, 05:15
Question ANSYS System coupling for the problem of pipe thermal expansion
Almir Zinnatullin
Alzy is on a distinguished road
Hi everyone,
I'm trying to evaluate how pipe's thermal expansion due to a flow of hot air inside it affects the flow. It is supposed to be a steady-state simulation. I understand that I should couple ANSYS CFX, Steady-state Thermal and Static Structural results while solving. I have seen lots of tutorials on two-way fluid-solid interaction, yet there are only pressure fields exported from CFX/Fluent.
The problem is that I have to make solvers share not only pressure fields (on pipe surface) but also temperature ones (firstly, on internal pipe's surface, from CFX to Steady-state Thermal, then from Steady-state Thermal to Static Structural to evaluate displacements in pipe).
I tried to solve the problem using Ansys System Coupling, but it doesn't support 3 analysis systems. I'm aware of Ansys Multifield, yet don't have a clue how to use it.
Does anyone have suggestions? Is it possible to solve the problem using two-way FSI?
Alzy is offline   Reply With Quote
Old   May 12, 2020, 10:07
Erik
evcelica is on a distinguished road
You don't need 2-way FSI. Why do you need steady state thermal if you have already solved for the pipes Temperature in CFX? Or did you leave the pipe out?
I any case, just export your data of interest from CFX post as a table of values (x,y,z,T). (File >> Export) Use "external data" in workbench to use that table in any other mechanical analysis.
evcelica is offline   Reply With Quote
ansys cfx, mesh displacement, thermal analysis
A CFX-POST error (ver 14.5.7) wangyflp88 CFX 2 July 22, 2017 01:17
problem memory in system coupling (possible problem of windows 8) 40nainer ANSYS 0 April 2, 2014 05:56
System Coupling Restart Problem SonyCFD FLUENT 3 March 27, 2014 09:31
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 22:31
Info: Short Course On Thermal Design of Electronic Equipment Arnold Free Main CFD Forum 0 August 10, 1999 11:18
