Obtaining negative pressure transients
Old   May 7, 2020, 11:39
Default Obtaining negative pressure transients
John Applesmith
ns778 is on a distinguished road
I need to obtain dp/dt in a fluid domain so for each node I'd like to obtain how much the absolute pressure changes from the last time-step. I can then divide by the time-step to get dp/dt.
Additionally, I would then like to index the maximum pressure transient over the volume at each time-step and plot the maximum obtained dp/dt against simulation time. There are moving immersed solids in my simulation if it makes a difference. I am simulating the flow across an aortic bi-leaflet valve.
Thanks.
ns778 is offline   Reply With Quote
Old   May 7, 2020, 14:42
Opaque will become famous soon enough
In case it helps, you should be able to use (only in the solution step)
Absolute Pressure.Time Derivative
in any expression as well as the RHS of an algebraic Additional Variable.
Note: I do not answer CFD questions by PM. CFD questions should be posted on the forum.
Opaque is offline   Reply With Quote
Old   May 10, 2020, 05:04
John Applesmith
Hi, is this a Derived Variable to be added in the workspace during a run? I can't find this function in the documentation anywhere but sounds exactly what I need.
Old   May 10, 2020, 21:25
What do you need to do with it? Use it in an expression? or copy it into another variable?
For an algebraic additional variable, you can do
Additional Variable Value = Absolute Pressure.Time Derivative
or use as part of any expression:
MyExpression = 2 * Absolute Pressure.Time Derivative
Old   May 11, 2020, 03:46
John Applesmith
Hi, I saw your message on a similar thread years ago and just added Absolute Pressure.Time Derivative as CEL in Set-Up: many thanks.
Is it possible to access the volume-maximum of this value at each time-step? So I could plot dp/dt against t and identify when in the simulation the maximum pressure transient occurs and then where using an isosurface? I'm unsure of how to access the domain maximum of a value at a time-step and have 0 experience with Fortran or User Routines.
Old   May 11, 2020, 06:34
Most functions in CFX can be done using CEL and do not need user fortran.
To get the maximum of this function at each timestep use the CEL expression:
maxVal(MyExpression)@Domain Name
Look in the CFX Reference manual for the other available CEL functions and expressions.
Old   May 11, 2020, 08:30
Old   May 11, 2020, 10:40
John Applesmith
Hi, I tried your method and got the following error
"The function 'maxVal' referenced by parameter 'Expression Value' in object '/FLOW:Flow Analysis 1/OUTPUT CONTROL/MONITOR OBJECTS/MONITOR POINT:transPress' has an invalid argument, 'Absolute Pressure.Time Derivative'. The solver does not support the use of this operator for this variable when used as an argument for this function.
I get similar messages no matter where I try to create the function- Set-Up CEL, as Monitor Point or in Post. The formula I'm using- maxVal(Absolute Pressure.Time Derivative)@tubeFluid. Even when I define the pressure transient separately and pass it into maxVal. What does work is Absolute Pressure.Time Derivative on its own.
Old   May 11, 2020, 11:40
As a workaround, you can always copy a valid variable into an Additional Variable (which usually works everywhere else),
Create an additional variable: (unspecified) with units = [Pa s^-1]
Activate the additional variable within a domain
Select Algebraic Additional Variable
Set it equal to = Absolute Pressure.Time Derivative
Try using the Additional Variable in those places you need it,
Old   May 14, 2020, 14:08
John Applesmith
Worked perfectly- thank you so much!
post, pressure transients, results
[Other] mesh airfoil NACA0012 anand_30 OpenFOAM Meshing & Mesh Conversion 13 March 7, 2022 18:22
static vs. total pressure auf dem feld FLUENT 17 February 26, 2016 14:04
[blockMesh] error message with modeling a cube with a hold at the center hsingtzu OpenFOAM Meshing & Mesh Conversion 2 March 14, 2012 10:56
seeking for help about a room with negative pressure mengyue1 FLUENT 0 November 26, 2009 07:40
negative pressure mAx FLUENT 0 January 25, 2006 15:31
