Sign Convention of the Total Pressure
Old   June 6, 2006, 10:35
Default Sign Convention of the Total Pressure
Cuong Nguyen
I have a model of fluid flowing through a square cylinder. My interest is total pressure on the surfaces of the cylinder but I am confussing about the sign convention of the pressure.
If anyone knows the sign convention of the total pressure in CFX, please give me some advices.
Thank you very much for your help!
NKC
Old   June 6, 2006, 10:46
Default Re: Sign Convention of the Total Pressure
Robin
The pressure is relative to the Reference Pressure you specified in your Domain.
Old   June 6, 2006, 21:35
Cuong Nguyen
Hi Robin,
Value of the pressure is ralatived to the Reference Pressure as you mentioned. But my question is about the direction of the pressure (we may get positive or negative value of pressure at a point on the surface of model), I am wondering that if the pressure is positive then the direction is going inward or outward of the surface or is there any other convention for that.
Can you give me any suggestion for that?
Thank you very much!
NKC
Old   June 7, 2006, 17:31
Robin
Hi Cuong,
There is no such thing as negative pressure, even on your surface. Pressure is always positive. The force due to pressure may be negative in a particular direction, however. Force due to pressure is always normal to the surface, but there may be a tangential component due to viscous stresses.
Regards, Robin
Static Pressure, Total Pressure ufechner FloEFD, FloWorks & FloTHERM 5 March 2, 2015 08:56
Neumann pressure BC and velocity field Antech Main CFD Forum 0 April 25, 2006 03:15
total pressure in CFX Atit Koonsrisuk CFX 0 January 1, 2005 06:46
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 06:13
Hydrostatic pressure in 2-phase flow modeling (long) DS & HB Main CFD Forum 0 January 8, 2000 16:00
