moving mesh
Old   June 5, 2006, 23:59
Default moving mesh
haribalan
I am looking for algorithm to implement moving mesh in 3 dimensions for internal incompressible flow moving boundary problem. CFX uses a approach for its moving grid option but i couldnt find it.
Specifically, the problem is as follows - The location of all boundary points is known apriori as function of time (user-defined). Before i could go to next timestep, the algorithm should alter/relocate all 'interior' mesh points accordingly. Local refinement of mesh is also not required between timesteps.
Thanks in advance
Old   June 6, 2006, 09:26
Default Re: moving mesh
Joe
CFX can handle this. Moving meshes are well documented in the manual. Search for "mesh deformation" and do the FSI tutorial ...
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 09:54
How to let the mesh motion solver just solve a small region near a moving boundary? zhajingjing OpenFOAM Running, Solving & CFD 9 April 28, 2016 05:15
[snappyHexMesh] external flow with snappyHexMesh chelvistero OpenFOAM Meshing & Mesh Conversion 11 January 15, 2010 20:43
Waves halted by moving mesh Piotr Czajko COMSOL 1 November 24, 2007 03:00
