Solver settings: Coupled, multi-grid, control-volume-based solver |
April 30, 2020, 09:34 |
Rep Power: 6 |
Hello guys, I would like to replicate the CFX simulations study in this article but I am not quite sure with what solver settings are they using. There is a section where they mentioned about the solver settings but I am not sure what are they describing.
What is meant by "a coupled multi-grid control-volume-based solver was used to discretize and solve the steady, compressible continuity and Navier-Stokes equations". And also this sentence The multi-grid based approach employed allowed for accurate calculations of long wavelength effects while the coupled aspect of the solver handled local effects How can I apply all the settings that is mentioned to the CFX analsysis. Anyone kind to explain the details of it to me? Would appreciate the effort! p.s. link of the article : https://link.springer.com/article/10...404-009-0452-3 pg 78 Attached screenshot of the article |
April 30, 2020, 10:17 |
Rep Power: 33 |
The highlighted text corresponds to the ANSYS CFX defaults, i.e. you do not need to search/modify anything.
The only important part you must set is the heat transfer model to use the Total Energy option
April 30, 2020, 10:19 |
Rep Power: 6 |
May 1, 2020, 07:01 |
#4 | |
Rep Power: 6 |
" Mesh motion was incorporated in the CFX model to include surface velocity components normal to the boundary." Do you mind explaining how to apply this condition? |
May 1, 2020, 08:20 |
Rep Power: 33 |
Check in the documentation for mesh deformation.
Keep in mind that a velocity normal to a wall boundary implies a deformation of the domain; therefore, other models must be activated.
Pressure Based Coupled Solver | A.S. | Main CFD Forum | 1 | November 8, 2015 10:59 |
Element based control volume method | kamyar | Main CFD Forum | 0 | July 3, 2013 15:03 |
Pressure Based Coupled Solver | A.S. | Main CFD Forum | 3 | September 23, 2007 23:48 |
compressible two phase flow in CFX4.4 | youngan | CFX | 0 | July 2, 2003 00:32 |
CFX 5.5 | Roued | CFX | 1 | October 2, 2001 17:49 |
