So what can we look forward to in CFX 11?
Old   May 30, 2006, 20:15
Default So what can we look forward to in CFX 11?
Coanda
Or is Ansys keeping it all under wraps?
Old   May 31, 2006, 03:28
Default Re: So what can we look forward to in CFX 11?
Charles
I have played with a preview of it. I was specifically looking at its ability to calculate ship waves, and it is doing a very good job of it, much better than CFX 10 or 5.7.
Old   May 31, 2006, 07:19
Coanda
Have they implemented a wave function BC or is it more about fiddling with the actual free surface models?
Old   May 31, 2006, 07:23
Charles
No, this is the VOF model
Old   May 31, 2006, 15:48
Michael
Spaceball support!!
Old   June 1, 2006, 08:34
Stuart
??? Whats "Spaceball support" when its at home ???
Old   June 1, 2006, 18:10
Poldu
Can cfx work with cad, does ansys model goes directly into cfx 11 integrated with PLM tools?
that is what they need!
P.
Old   June 1, 2006, 19:10
Joe
ICEMCFD has a nice plugin for ProEngineer which I use all the time ...
Old   June 2, 2006, 09:05
Michael
http://www.3dconnexion.com/
use it all the time in ICEM, Unigraphics, Workbench, etc.
Old   June 5, 2006, 23:41
HekLeR
Ask your support rep for a preview. Preview 4 has been available for a while now and new capabilities were presented at the ANSYS user conference in April.
There is a lot, but new model-wise the lay of the land is something like this:
- Performance: Speed improvments on all platforms, parallel speed improvements esp for cases with GGI interface models
- Multiphase: significant free surface model numerics improvements inc coupled volume fractions (huge stability improvments), non equilibrium droplet condensation model with nucleation predicition (MOM based)
- Particle tracking: spray injection primary breakup models, spray penetration diagnostics, moving mesh support completion
- Mesh morphing: 2nd order transient conservative mass discretisation, steady state calcs, new mesh stiffness recipes, improved accuracy GGI interfaces, easier setup with GGI, mesh quality diagnostics
- Radiation: transparent radiation mode (surface to surface monte carlo), speed improvements
- Solver CEL: inside()@region function, callback functions on all mesh regions, approximate flows on non BC mesh regions, coordinate frame usage improvements
- Turbulence: SAS-SST model, Kato Launder production term mod for k-epsilon, more beta models... eg: Spallart Allmaras
- Combustion: partially premixed combustion improvments: weighted reaction progress model, spark ignition model, NOx post processing mode, new laminar/turbulent burning velocity models
- 3D Interpolation: Complete rewrite, insanely faster than CFX 10.
- Properties: IAPWS (ASME) steam equation of state, peng robinson equation of state, isentropic/polytropic- compression/expansion efficiency monitoring & post processing
- Boundary conditions: total enthalpy condition, periodic mass flow/pressure change condition, more acoustic non-reflecting boundary conditions, monopole source output for noise models, Lighthill stress output for noise models
That is not everything either...
CFX Treatment of Laminar and Turbulent Flows Jade M CFX 18 September 15, 2022 08:08
Different flow pattern between OpenFOAM and CFX AirS OpenFOAM 0 January 12, 2010 08:08
heat generation in CFX Ema CFX 4 August 7, 2009 06:39
CFX 10's solutions differ from CFX 5.7's Atit Koonsrisuk CFX 4 July 26, 2006 12:59
CFX 4.4 installation problem Pandu Sattvika CFX 1 December 1, 2001 05:07
