April 24, 2006, 11:22 |
Problems with "Refinement"
Hello everybody!
I am simulating an 3D air flow through a brush seal in a steam turbine. I try to refine my mesh in particular locations. For this i use the function "Refinement" to increase the dense in two directions. When I try to write a solver file for CFX5 I always get following error message: Error: Running ICEMCFD - CFX5 Interface Vers. 5.1.1 child process exited abnormally Running ICEMCFD - CFX5 Interface Vers. 5.1.1 child process exited abnormally while executing "exec C:/Programme/AnsysInc/v90/icemcfd/5.1-win/icemcfd/output-interfaces/cfx5-dom./hex.uns-b./family_boco.fbc-ascii-internal _faces./cfx5" ("eval"body line 1) invoked from within "eval exec $args" (procedure "ic_exec" line2) invoked from within "exec C:/Programme/AnsysInc/v90/icemcfd/5.1-win/icemcfd/output-interfaces/cfx5-dom./hex.uns-b./family_boco.fbc-ascii-internal _faces./cfx5" invoked from within "batch_interp eval ic_exec $args" (What a long error-message) I don't know what this message is trying to tell me and what I can do to make it work. Advices are welcome. Thanks a lot, greetings Christian |
April 24, 2006, 14:41 |
Re: Problems with "Refinement"
I think not even the Oracle of Delphi knows what ICEM error messages are trying to tell you. My favourite is the "Warning: Application terminated with base class destructor" or something similar which is the message from the Prism mesher telling you that everything went just fine....
Anyway, jokes aside, that message just says the output translator crashed, not why. You might check to see if the translator left some kind of log file behind which might have more info. Also running the mesh checks usually is a good way to get information on what may be the cause, since the crash is propably caused by some abnormal element that causes the translator to get lost. Unless of course you are running into memory problems, like disk full or no RAM left. But I'm shure you already checked those, right? /C |
[ICEM] Problems with coedge curves and surfaces | tommymoose | ANSYS Meshing & Geometry | 6 | December 1, 2020 11:12 |
[snappyHexMesh] Boundary layer in a pipe | Clementhuon | OpenFOAM Meshing & Mesh Conversion | 6 | March 12, 2012 12:41 |
[snappyHexMesh] snappyHexMesh aborting | Tobi | OpenFOAM Meshing & Mesh Conversion | 0 | November 10, 2010 03:23 |
[snappyHexMesh] Boundary layer generation problems | ivan_cozza | OpenFOAM Meshing & Mesh Conversion | 0 | October 6, 2010 13:47 |
Refinement and boundary problems | Julie Polyakh | Siemens | 4 | December 16, 2001 08:17 |
