April 5, 2020, 05:38 |
#21 |
Rep Power: 144 |
Sorry, I forgot that this was applied to a VOF model. Yes, you need a VOF model for the free surface and Lagrangian particles for your particles to track.
April 5, 2020, 07:58 |
#22 |
Saeed Pashazanousi
Rep Power: 6 |
April 5, 2020, 18:00 |
#23 |
Rep Power: 144 |
Look at the tutorial examples to see how to set up a particle tracking simulation.
Don't ignore the convection only additional variable suggestion I made right at the start. This approach is MUCH easier to implement and might be good enough for you.
April 6, 2020, 05:16 |
#25 |
Gert-Jan
Rep Power: 28 |
You only defined how particle look like and their interaction with air.
But where do you inject them? |
April 6, 2020, 05:25 |
#26 |
Saeed Pashazanousi
Rep Power: 6 |
I don't want do Inject them...I want some particle to plot their path vs simulation time...If I define Inection region I should more than 100 region...let's assume I create region...I define mass flow rate and injection velocity and then what happen?...I get the desire result?...How I plot the particle path?
April 6, 2020, 05:46 |
#27 | |
Rep Power: 144 |
First of all, let me repeat this for the third time:
And regarding Lagrangian particle tracking - all the basics are covered in the CFX tutorials available in the CFX documentation and the ANSYS Customer webpage. This includes how to set them up and how to visualise them. I also recall saying previously that you cannot use an injection region to place your particles. The ONLY way to place particles in specific locations is using a user fortran routine.
April 9, 2020, 04:18 |
#28 |
Saeed Pashazanousi
Rep Power: 6 |
Thank you ghorrocks;
I want to learn Fortran for cfx...I'm looking for a Tutorial...a proper one...
Best regards Saeed Pashazanousi Urmia University Email: st_s.pashazanousi@urmia.ac.ir |
April 9, 2020, 12:41 |
Wave Maker
#29 |
Saeed Pashazanousi
Rep Power: 6 |
I define a material with Water at 25 properties.
I define a injection region. Simulation time:0.02 [s],Step:0.01 [s] But error occur and the result is unacceptable... A.jpg B.jpg C.jpg D.jpg E.jpg
April 9, 2020, 21:27 |
#30 |
Rep Power: 144 |
We are wasting our time here. Can you please try the additional variable approach I have suggested? The Lagrangian particle approach is not simple and you will need a lot more experience in CFD before you will get that working.
I am not going to help you further on this thread if you persist with the Lagrangian particle tracking. I will only assist you with the additional variable approach.
April 10, 2020, 18:06 |
#31 | |
Saeed Pashazanousi
Rep Power: 6 |
How I can create velocity vector,start from end point of previous step Vectors?
April 10, 2020, 21:05 |
#32 |
Rep Power: 144 |
I don't understand your question, can you ask it again please? I also do not understand what relevance it has to this thread.
April 11, 2020, 18:24 |
#33 | |
Saeed Pashazanousi
Rep Power: 6 |
I have 3 new Question?... 1-what do int() and sum() functions do? 2-How I can define a expression with algebraic equations? 3-I want to plot acceleration,I should use differential equation or I want use Integral to obtain displacement of a particle from velocity...I can use Integral or differential to define variable or expression? thanks for your attention
Best regards Saeed Pashazanousi Urmia University Email: st_s.pashazanousi@urmia.ac.ir Last edited by pashazanousi; April 11, 2020 at 18:34. Reason: Extra |
April 11, 2020, 21:35 |
#34 |
Rep Power: 144 |
Plotting velocity vectors is a basic post-processing task. The vectors are drawn at seed points. This is all covered in the CFX tutorials. You really should do the tutorials so you understand the basics.
1) I assume you are asking about the CEL expressions. These are all described in the CFX reference guide. 2) This is covered in the CFX tutorials. Please do them, you are wasting everybody's time unless you know the basics. 3) Acceleration of what?
April 13, 2020, 16:33 |
#35 | |
Saeed Pashazanousi
Rep Power: 6 |
I'm sorry... I search tutorial but I couldn't understand something and sometimes I ask simple Questions.. I'm really sorry... I want to create a point that It's position is function of a variable... I explain more... I want to plot a particle path... Let's assume Initiall position is (X, Y) ... Then Next step Position will be as follow: x=X+U*t y=Y+V*t t: constant time step U:Velocity x direction V:Velocity y direction If I can define the point with (x, y) then I can plot the particle path... Even I can make animation of trajectory... It is possible to define point like this?
July 16, 2023, 10:30 |
#36 |
Saeed Pashazanousi
Rep Power: 6 |
This question was long ago, but it is worth saying that I plotted particle paths using Ansys's Ensight. It is a post-processing module in Ansys Workbench. It calculates particle path in a few simple steps and illustrates particle movement as animation. It offers various visual options you can customize for the desired results.
ansys 14 cfx, cfx |
wave maker | wave maker | CFX | 12 | July 10, 2020 04:35 |
Coffee Coffee Maker Station Ways to Make | lichypanta | Main CFD Forum | 0 | June 16, 2016 03:18 |
Simulating Ice Accretion in CFX | agner583 | CFX | 3 | February 11, 2014 00:50 |
solving ocean wave with Fluent or CFX? | gholamghar | Main CFD Forum | 1 | March 21, 2009 12:49 |
Question about the shock wave in CFX software | nucharin | Main CFD Forum | 1 | January 25, 2005 08:26 |
