how to create intersection line of two surfaces
Old   March 5, 2020, 16:39
Default how to create intersection line of two surfaces
phd
lostking18 is on a distinguished road
Hi, there
I have generated a surface with constant radius and a surface inserted from external .stl file. Now I need to generate the intersection line of these two surfaces, how could I generate it in CFX post? I can’t do that with function ‘polyline’ because the .stl file created surface is not in the ‘boundary list’.
Thank you very much!
lostking18 is offline   Reply With Quote
Old   March 5, 2020, 17:49
Why are you doing this in CFD-Post? This sounds like a solid modelling question to me.
Note: I do not answer CFD questions by PM. CFD questions should be posted on the forum.
Old   March 5, 2020, 18:10
phd
Hi, Glenn, thank you for your always helpful reply. I need to generate a curve in the flow field to measure the pressure profile along this curve. The intersection of these two surfaces is the easiest way for me to get this curve. Also in the practice of implementing CFX post, I always find it is helpful to have the intersection of two surfaces. But for some reason in the polyline function of CFX post, one of the surface has to been the boundary surface, which from my opinion significantly restrice the usefulness of the function. I don't why there is such restriction.
Old   March 5, 2020, 18:46
CFD-Post is a post processing software, so think from a developers point of view - why would it allow calculation of curves of arbitrary surfaces? That is not a post processing function, it is a solid modelling function.
I think you are going to have to work out the intersection line in a solid modelling package, then export the line (as points or something like that) from the solid modelling package and import them into CFD-Post.
Old   March 9, 2020, 02:11
urosgrivc
urosgrivc is on a distinguished road
Try this:
Make a CONTOUR on your imported stl.surface which will be coloured by RADIUS
this will give you contour lines with some radial spacing, one of these will be the line you want...
now you can select a POLYLINE and select contour which you have just made and the level you want to observe, hide the previously generated contour
now the generated poliline is hopefully where you want to observe your data
this should be it
urosgrivc is offline   Reply With Quote
cfx post 19.1
problem during mpi in server: expected Scalar, found on line 0 the word 'nan' muth OpenFOAM Running, Solving & CFD 3 August 27, 2018 05:18
[Other] Compiling hacFoam (Ubuntu 10.04)(OF2.0.0)(LAMMPS13Jul2010)) Henrik_E OpenFOAM Installation 3 September 29, 2016 17:16
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 03:09
[General] 2 datas on one plot Akuji ParaView 46 December 1, 2013 15:06
