HS
Rep Power: 11 ![]() |
Hi All,
I am running a transient simulation of flow through a pipe where there is an inlet and two outlets. I am using a fourier series to define the shape of the pulsatile flow. Currently I am defining my flow using velocity by implementing the following expressions: v0 = 0.2 [m/s] vinlet = v0*(a0 +a1*cos(-2*pi*1*f0*t) +b1*sin(-2*pi*1*f0*t) +a2*cos(-2*pi*2*f0*t) +b2*sin(-2*pi*2*f0*t) +a3*cos(-2*pi*3*f0*t) +b3*sin(-2*pi*3*f0*t) +a4*cos(-2*pi*4*f0*t) +b4*sin(-2*pi*4*f0*t) +a5*cos(-2*pi*5*f0*t) +b5*sin(-2*pi*5*f0*t) +a6*cos(-2*pi*6*f0*t) +b6*sin(-2*pi*6*f0*t) +a7*cos(-2*pi*7*f0*t) +b7*sin(-2*pi*7*f0*t) +a8*cos(-2*pi*8*f0*t) +b8*sin(-2*pi*8*f0*t) +a9*cos(-2*pi*9*f0*t) +b9*sin(-2*pi*9*f0*t) +a10*cos(-2*pi*10*f0*t) +b10*sin(-2*pi*10*f0*t) +a11*cos(-2*pi*11*f0*t) +b11*sin(-2*pi*11*f0*t) +a12*cos(-2*pi*12*f0*t) +b12*sin(-2*pi*12*f0*t) +a13*cos(-2*pi*13*f0*t) +b13*sin(-2*pi*13*f0*t) +a14*cos(-2*pi*14*f0*t) +b14*sin(-2*pi*14*f0*t) +a15*cos(-2*pi*15*f0*t) +b15*sin(-2*pi*15*f0*t) +a16*cos(-2*pi*16*f0*t) +b16*sin(-2*pi*16*f0*t) +a17*cos(-2*pi*17*f0*t) +b17*sin(-2*pi*17*f0*t) +a18*cos(-2*pi*18*f0*t) +b18*sin(-2*pi*18*f0*t) +a19*cos(-2*pi*19*f0*t) +b19*sin(-2*pi*19*f0*t) +a20*cos(-2*pi*20*f0*t) +b20*cos(-2*pi*20*f0*t)) And then setting Normal Speed at the inlet boundary and using vinlet as the input. I now want to define the pulsatile flow by setting a fixed flow rate of 1.0 [ml/s] at the inlet. Any suggestions on how I can modify the above expressions to do this? |
Gert-Jan
Rep Power: 27 ![]() |
How can it be pulsating if you have a fixed flow rate? This is only possible if you have a gas with a pulsating density. Is this what you are looking for?
Unfortunatley, you can not vary the density on the inlet directly. You can vary pressure on the inlet, but then the inlet massflow will also change. This is simply the outcome of the simulation. However, if you set a massflow on the outlet then the software will try to keep everything in balance as fast as possible, i.e. speed of sound. So the massflow on the inlet will lag a bit behind on your outlet massflow. The way it will keep up depends on the length and size of your volume. If this is large, then this will damp out the pressure fluctuation. Not sure if this is a valid and stable combination of boundary conditions. I would give it a try. I think at least you need small time steps in your transient simulation....... |
flow rate, inlet flow profile, pulsatile flow |
Flow rate restriction simulation set-up | siw | CFX | 4 | February 16, 2016 12:15 |
Discrete Phase & Mass Flow Rate | MagnusZeus | FLUENT | 0 | December 2, 2011 17:57 |
Constant flow rate through a small area inside the fluid domain. | robingilbert | OpenFOAM | 7 | October 4, 2010 16:19 |
Constant Volumetric Flow Rate Boundary Condition | Hadley | Main CFD Forum | 0 | October 20, 2005 23:13 |
Constant mass flow rate / choking outlet bounardy condition | Min Zhu | Main CFD Forum | 1 | September 29, 1998 15:33 |
