MPI Abort
Old   February 22, 2020, 03:48
Post MPI Abort
Sidharth K PIllai
Sidharthkp is on a distinguished road
I am receiving an error message in my workstation while running an "Omega Reynolds stress" based simulation of annular heat transfer in a concentric cylinder arrangement with inner cylinder heated and outer cylinder rotating.
My mesh is hexahedral with 66 lakh elements
I initialized the model from a laminar flow result.
I run it on local mpi parallel in 10 logical processors.
I dont know that the issue is, I have tried reinstalling ANSYS 18.2, but same error is happening after about 60 iterations.
I am also attaching the text file and error message pic also. Please help me ...
Sidharthkp is offline   Reply With Quote
Old   February 22, 2020, 04:28
M
AtoHM is on a distinguished road
The actual error message is an overflow in linear solver.
Check the FAQ's https://www.cfd-online.com/Wiki/Ansys_FAQ.
AtoHM is offline   Reply With Quote
Old   February 23, 2020, 17:09
Gert-Jan
Gert-Jan will become famous soon enough
Why on earth would you think that it has to do with the installation? It is just a matter of bad settings. E.g., I would never start a solution using Reynolds stress. First run it with SST and then restart with Reynolds stress, using a timescale factor 0.3.
Gert-Jan is offline   Reply With Quote
Error running openfoam in parallel fede32 OpenFOAM Programming & Development 5 October 4, 2018 17:38
How to setup a simple OpenFOAM cluster? TommiPLaiho OpenFOAM Installation 3 October 27, 2013 16:15
OpenFOAM compile error balkrishna OpenFOAM Installation 9 June 17, 2011 04:53
Compiling OpenFOAM on hpc-fe.gbar.dtu.dk kaergaard OpenFOAM Installation 1 June 16, 2011 02:33
Error using LaunderGibsonRSTM on SGI ALTIX 4700 jaswi OpenFOAM 2 April 29, 2008 11:54
