Missing water flow in sub-inlets
Old   February 17, 2020, 14:42
Default Missing water flow in sub-inlets
Dyuthi
Dsreedeth is on a distinguished road
Hi all! I am trying to simulate this system where cold water enters a main inlet manifold which feeds into multiple smaller rectangular channels which get collected at the bottom manifold and exits the system (essentially a simplified box-frame solar thermal collector-pic attached). While checking the results I figured that the water seems to enter only a few channels (pic of velocity streamline included). Is there anything I can do to ensure the water enters all the channels?
Dsreedeth is offline   Reply With Quote
Old   February 17, 2020, 17:11
Streamlines are not a reliable way to work out how much fluid is going though each passage. I will let you work out why
You should generate a cross section plane through the passages and look at the normal velocities. Even better, generate a plane for each passage and use the massflow() function to give the exact flow in each passage.
Note: I do not answer CFD questions by PM. CFD questions should be posted on the forum.
Old   February 18, 2020, 05:35
Dyuthi
Thanks for the suggestion. I generated the cross section plane and the velocity is zero in the channels where water does not enter. So is there any way I can ensure water enters these chanels?
Old   February 18, 2020, 06:11
Have a look at the pressure across your device. Here's a hint: If a channel has no pressure gradient along it then it will have no flow.
fluid dynamics, heat exchanger
problem with two phase flow (air injected in water) miles_davis OpenFOAM 15 March 31, 2021 10:36
Mass imbalance problem in multiphase water and steam CFX case Antech CFX 1 October 26, 2020 05:03
Flow of gas and water in concentric pipes AS_Aero CFX 6 October 2, 2018 19:13
For a single phase flow, is there any way to check water surface level? Tanjina FLUENT 0 February 23, 2014 23:56
uptodate water distribution network fredius,magige,tanzanian,(e.a) Main CFD Forum 0 January 27, 2002 08:10
