Alternate rotation method
Old   February 12, 2020, 12:18
Default Alternate rotation method
Sai Paruchuri
paru is on a distinguished road
I am simulating flow through an axial pump (by specifying total pressure at inlet and static pressure at outlet), so bulk of the flow is moving in the axial direction. I observe some spurious vectors in the blade tip gap and swirl at the interface between rotating and stationary domain. Also the flow rate is much less than measured value. For a coarse mesh, when I turned on the alternate rotation method, it seemed to correct the flow vectors and the flow rate value. However, with a fine mesh, the swirl continues to exist and the simulation gives a low flow rate despite turning on the alternate rot method. Kindly help me understand what's happening!
paru is offline   Reply With Quote
Old   February 12, 2020, 13:38
Gert-Jan
Gert-Jan will become famous soon enough
We need a screendump to really make a good comment.
However, a mistake people quite often make is that they judge this kind of simulation by looking at the vectors and flow with variable "Velocity". I suggest to look at "Velocity at Stn Frame"
Gert-Jan is offline   Reply With Quote
Method similar to MRF for Fan rotation arulnambi_palani Main CFD Forum 0 July 19, 2019 05:18
Vortex Panel Method Rafaelle55 Main CFD Forum 1 December 17, 2018 11:16
On the alpha Eqn of VOF method when using Immersed boundary method in OpenFOAM keepfit OpenFOAM 4 January 31, 2014 15:32
multiphaseEulerFoam: method mag(...) withing method solveAlphase() maybee OpenFOAM Programming & Development 0 December 21, 2013 11:13
Help about the preconditioner in gmres method Dan Gao Main CFD Forum 3 July 5, 2008 02:18
