Air without Boussinesq approximation
Old   February 12, 2020, 06:44
Post Air without Boussinesq approximation
Sidharth K PIllai
Sidharthkp is on a distinguished road
I am doing a natural convection problem with imposed rotation in an annular space using ANSYS CFX as part of my academic work(yes I am new to this). My Temp difference (Ts-Ta) is around 20 degree which is above the boussinesq approximation limit(15deg.).
My problem is with material option.
When i choose ideal gas(in which i persume boussinesq is not used as i specify the reference temp), I am getting results very close to real situation.
When i choose "air at 25deg" option where density is treated as const property and bousinessq is applied by default, temperatiure is overpredicted by more than 10degree.
My doubt are:
1. how can i apply a fluid which is not treated as ideal and also boussinesq is not applies as well. The third option in materials eqn of state is defining it as 'real gas', but i don't know how to obtain all values that i have to specify in it.
2. Is there any other way in which I can choose a library fluid (air) by not choosing boussinesq approximation?
Sidharthkp is offline   Reply With Quote
Old   February 12, 2020, 07:15
1) Have a look in the CFX tutorial examples on real gas. You can get them from the ANSYS Customer site.. Not sure if the ANSYS Student Portal has them, it is a bit advanced for a student application.
2) Boussinesq approximation is the only constant density approach to bouyancy in CFX. The alternative is to define a density function versus temperature and then that will define the buoyant effects. A simple function would be ideal gas, but real gas and other EOS are also applicable.
Note: I do not answer CFD questions by PM. CFD questions should be posted on the forum.
Old   February 14, 2020, 05:32
Smile
Sidharth K PIllai
Thank you for the reply.
I would try your suggestions and come back if anything troubles me
boussinesq approximation, cfx 18.2
Simulation crashes when turbulence is on (reactingMultiphaseEulerFoam) remidemol OpenFOAM Running, Solving & CFD 3 May 26, 2020 06:47
Boussinesq approximation tahtawy Main CFD Forum 9 September 11, 2019 04:49
natural convection in square cavity without using Boussinesq approximation rahul62 OpenFOAM 0 February 21, 2018 06:48
Non Boussinesq approximation design_amrita Main CFD Forum 6 February 6, 2013 10:01
air bubble is disappear increasing time using vof xujjun CFX 9 June 9, 2009 08:59
