Creating 2D geometry with ICEM
Old   April 10, 2006, 11:50
Default Creating 2D geometry with ICEM
TobiasZ
Dear all,
I need to create a quasi 2D model in ICEM 10.0.1 for Tetra elements. I've heard this is possible by creating a surface mesh and extruding the surfcase mesh by 1. However, after I have created a surface mesh solely (no volume mesh), I can not pick anything for "Elements" in the Extrude Mesh option. Anybody here who can help? Thanks
TobaisZ
Old   April 12, 2006, 02:59
Default Re: Creating 2D geometry with ICEM
TobiasZ
hi again,
perhaps there is someone who can tell me briefly step by step how to create a quasi-2D mesh. Thank you for your help.
TobiasZ
Old   April 12, 2006, 10:17
myron
It should simply work. If you click on the 'Select elements' icon in the extrude mesh panel it should allow you to select the elements to extrude. Then you can select individual elements, by part, etc. Or if you want to extrude all your surface mesh - just hit 'a' on the keyboard for all elements.
Old   April 13, 2006, 03:50
TobiasZ
Thanks. Well, I managed to select all elements, but only when I have created a 3D geoemtry and a surface mesh for all surfaces. Then extruded elements look rough not having smooth surface (maybe this is because of wrong element surface normal directions of some elements). But how to extrude one layer width from a 2D plane surface? Do you have any idea?
TobiasZ
Old   April 13, 2006, 05:32
Default Re: 2D geometry with prism inflation
TobiasZ
Hi, OK, I found a way to extrude the mesh from a plane. Is it correct having no surface mesh for the other geometry parts then? But how to include prism inflation from other parts, if no surface mesh exists there? Do I need to set prism inflation before extrusion? If so, how to do prsim inflation on this surface?
Thanks for anyones help in advance.
TobiasZ
[ICEM] Geometry in ICEM CFD DaIN ANSYS Meshing & Geometry 7 January 3, 2012 12:32
[ICEM] Icem Geometry creation strategy for hollow cube tony00 ANSYS Meshing & Geometry 1 March 16, 2011 12:05
flow over an airfoil 3d ( Geometry on icem cfd ) dfmona Main CFD Forum 0 April 14, 2010 00:32
[Other] Creating a Simulation Geometry fishlurch OpenFOAM Meshing & Mesh Conversion 3 January 11, 2010 12:47
Creating a 2D Mesh using ICEM VSB CFX 0 November 1, 2006 23:17
