Boundary conditions for the transport of a new variable
Old   February 9, 2020, 00:47
Default Boundary conditions for the transport of a new variable
katty parker
katty17 is on a distinguished road
Hi All,
I want to model the transport of some species in a kind of plant. The problem setup is shown in the figure below:
Water enters the main tube (white rectangle) and then a part of it enters the side porous domain and the rest will leave the domain at the outlet.
As is shown in this figure, on the lateral wall of the porous media, an opening boundary condition with the pressure of 0 Pa is set. The value of the species on this boundary condition is also set to a fixed value.
The problem is that after that the solution converges, the value of species on the lateral wall of the porous domain is not equal to the specified value (0 mol/m3).
My question is that why the solution does not follow the value of the species that is enforced to be equal to 0 mol/m3 on this wall?
katty17 is offline   Reply With Quote
Old   February 9, 2020, 05:04
When an opening has outflow the boundary value of an AV is convected from inside the domain. In other words, you do not set the value (or the gradient).
Providing the fluid velocity is much faster than the diffusion velocity then this approach is valid. If your diffusion velocity is faster than the fluid velocity this approach is not valid and you are going to have to use another approach.
In other words, whether this is suitable depends on what you are doing and what the properties of the fluids are.
Note: I do not answer CFD questions by PM. CFD questions should be posted on the forum.
ghorrocks is online now   Reply With Quote
Old   February 9, 2020, 10:34
katty parker
Dear Glenn,
Thanks for your help.
So if I understood correctly, using this approach I need to adjust the fluid properties in the porous domain (let say using a trial and error approach) to make the value of AV equal to zero there.
May I ask you to please let me know about the alternative approachs?
Thanks.
Old   February 9, 2020, 18:22
No, you do not appear to have understood my comment. Please re-read my comment and also look at the CFX documentation about boundary conditions so you understand what you are doing.
Can we check what approach is correct first? What is the fluid velocity in the porous material? What is the diffusion velocity scale in the porous material? You need to figure that out to determine the correct approach.
My radial inflow turbine Abo Anas CFX 27 May 11, 2018 02:44
Multiphase flow - incorrect velocity on inlet Mike_Tom CFX 6 September 29, 2016 02:27
Problem with SIMPLEC-like finite volume channel flow boundary conditions ghobold Main CFD Forum 3 June 15, 2015 12:14
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 08:00
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 05:05
