Opening conditions in CFX
Old   February 7, 2020, 07:06
Default Opening conditions in CFX
M29
Sumin Park
M29 is on a distinguished road
Hello!
I encountered some problems in CFX.
First, I don't know exactly to set the opening conditions in cfx.
I want to simulate the cask that has heat source in the inner in the air and i want to see the heat transfer and velocity profiles near the cask outer.
So, in bottom of air domain, I set the wall condition.
And then, I set the opening conditions to side and top face of the air domain.
But, I don't know how to set details of opening conditions...
I use buoyancy model and I used following setting;
In opening condition details..
Mass and momentum - opening pressure and direction, Ref. Pressure : 0
Heat transfer - static temperature
Flow direction - I don' remember..
Thermal radiation - local temperature
In the air domain, there is no wind. just steady state.
How can i set the opening conditions for steady state air domain?
And what's means flow direction?
M29 is offline   Reply With Quote
Old   February 7, 2020, 19:45
Those questions are all dealt with in the CFX tutorials. Go to the ANSYS customer website (or the student portal if you are a student) and do the tutorial examples. They show you how to use the basics of the software.
Note: I do not answer CFD questions by PM. CFD questions should be posted on the forum.
Old   February 9, 2020, 11:35
M29
Sumin Park
So then, can i know the keyword about my simulation? I don't know what to search for..
Old   February 9, 2020, 18:18
Customers: https://support.ansys.com/portal/sit...emplate.LOGIN/
Students: https://studentcommunity.ansys.com/
Error while opening cfx file in cfx pre pks126 CFX 9 June 11, 2018 12:00
Setting up Boundary Conditions in CFX using .csv files. knikkhilraj CFX 2 May 7, 2018 09:12
Closest BC similar to 'Opening' BC in CFX praveengambhir16 FLUENT 1 July 15, 2017 11:02
How does CFX treat an opening when heat transfer is modelled? JuPa CFX 2 September 9, 2014 06:34
icem cfd geometry tin file not opening cfx 10 c mayur CFX 2 July 10, 2007 03:57
