how to calculate cd -- drag coefficient?????? |
April 6, 2006, 04:12 |
Hi, I have simulated the flow over an aerospace vehicle. Now I can get the drag force on the surface of the vehicle(with the help of readymade options that are available in CFX-post). I know that, cd = drag force / (dynamic pre * reference area). Whatever the cd that I have obtained is being half of the exact value. I am not getting the mistake. Plz help. Thank you.
April 6, 2006, 06:55 |
Re: how to calculate cd -- drag coefficient??????
OK, quick question, have you used a symmetry plane? If so, then you have to double the force. Stu
April 6, 2006, 09:01 |
Remember this computing task list: <Li> Lift is easy[*] Drag is hard[*] Moment is imposibble
- Michael |
April 6, 2006, 09:17 |
Hi I have obtained for a 3D wing a good results even for Cm Coeff. However its difficult to compare it to other methods since every numeric method has serious problems with moments.
April 6, 2006, 09:18 |
Check your reference area value
April 6, 2006, 20:07 |
Yes, check your reference area; but also most people calculate drag from Cd = D / (A * .5 * rho * V^2) (http://www.grc.nasa.gov/WWW/K-12/airplane/dragco.html) and that has a factor of 2 in it. If you left it out you would be out by exact 2! Maybe that's it. Regards, Glenn Horrocks |
April 7, 2006, 00:35 |
Thanks to all. I obtained the results.
Drag Coefficient Convergence Problem | John | FLUENT | 18 | June 24, 2023 10:22 |
Ahmed Body Coefficient of Drag how to calculate? | ha85 | FLUENT | 1 | December 19, 2009 13:17 |
Drag coefficient for parcels in dieselFoam | sebastian_vogl | OpenFOAM Running, Solving & CFD | 5 | December 31, 2008 13:19 |
Automotive test case | vinz | OpenFOAM Running, Solving & CFD | 98 | October 27, 2008 09:43 |
how can i calculate the lift and drag coefficient | yujun | Main CFD Forum | 5 | January 23, 2003 16:16 |
