Piecewise function to model time-dependant BC
Old   April 5, 2006, 03:03
Default Piecewise function to model time-dependant BC
Ramses Galaz
Hi
I am in the need to model the flow of blood passing through the coronary arteries. The inlet BC should be pressure driven by a typical Aortic Pressure Waveform which is a very oddly shaped function of Pressure vs. Time as some parts are linear and some quadratic or higher order.. it would be more accurate to model it as a piecewise function.
I need to know how to define piecewise functions in CEL expressions to model the time-dependant pressure at the inlet for this transient analysis.
Thanks
Old   April 5, 2006, 03:09
Default Re: Piecewise function to model time-dependant BC
TB
1)Make use of the step function. You can turn on/off an equation on a particular time range.
2)Just another suggestion. Create a 2D data with time & pressure and then import it to Pre using User Function.
Old   April 6, 2006, 11:00
Ramses Galaz
Thanks
It seems that your 2nd suggestion was better and quicker..
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 bookie56 OpenFOAM Installation 8 August 13, 2011 05:03
latest OpenFOAM-1.6.x from git failed to compile phsieh2005 OpenFOAM Bugs 25 February 9, 2010 05:37
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 21:50
Modeling in micron scale using icoFoam m9819348 OpenFOAM Running, Solving & CFD 7 October 27, 2007 01:36
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 15:00
