How to estimate the quality (mesh expansion factor) of the mesh at interface CFX? |
February 2, 2020, 10:10 |
Georgy
Rep Power: 15 |
Does anybody know how to assess quality of the mesh at interface? In particular, mesh expansion factor and volume change. ICEM CFD shows these parameters only in the domain on one side of the interface. I noticed that convergence can highly depend on interfaces in the computational domain. Although, quality of the mesh can be ideal on both sides of the interface still convergence can be far from ideal. At the same time, convergence can be improved if the mesh is built without interfaces even when the quality of the mesh is worse.
What does CFX exactly do at fluid-fluid interface? How does CFX construct a control volume on interface? Is there any literature to read about algorithms for computation through interface? |
February 2, 2020, 17:46 |
Rep Power: 144 |
The GGI interfaces are complex and described in the documentation.
Yes, your simulation is more numerically stable and accurate if the size of the elements is constant across the interface. But how significant this is will depend on what you are modelling and the physics you are using. Some will be highly sensitive and some not very sensitive at all. So your comments may well be correct for your application, but be careful when you think about generalising it to all applications.
February 12, 2020, 05:57 |
Georgy
Rep Power: 15 |
February 12, 2020, 07:18 |
Rep Power: 144 |
I am at home and don't have access to the software so cannot. But it is not hard - just do a search for General Grid Interface.
Radiation in semi-transparent media with surface-to-surface model? | mpeppels | CFX | 11 | August 22, 2019 08:30 |
Error - Solar absorber - Solar Thermal Radiation | MichaelK | CFX | 12 | September 1, 2016 06:15 |
expansion factor in mesh quality | wjy-c | CFX | 8 | August 25, 2013 01:04 |
[ICEM] trouble with mesh quality from ICEM in CFX Solver | escher25 | ANSYS Meshing & Geometry | 0 | February 28, 2011 08:38 |
CFX 5.4.1 mesh quality? | joseph | CFX | 9 | October 18, 2001 17:02 |
