Missing info from CFX 10 help file ?
Old   April 4, 2006, 10:26
Default Missing info from CFX 10 help file ?
Pete
I've some doubt about the search function in the help file supplied in CFX 10. When I search a string like "Streamline solver type", I get a few results but it's blank when I try to open the topics. I see only the title and without any information inside. Is that a bug?
Old   April 4, 2006, 13:50
Default Re: Missing info from CFX 10 help file ?
siv
yeah it may be bug. Even i too faced similar problem when i tried to do FSI exmaple in Conjugate heat tranfer tutorial. Refer 5.7.1 tutorials.
Old   April 4, 2006, 14:03
Robin
Try the PDF doc instead. You'll find it in the <CFX_ROOT>/help/pdf directory.
Old   April 5, 2006, 02:52
Default How to know which pdf file contain the right info?
Pete
Hi Robin,
Is search engine available to tell which pdf files contain a particular string? I have to open all pdf files in the directory in order to hunt for a certain information. I used the following command in /help/pdf but it only showed me lots of craps.
ls *.pdf | xargs grep -i streamline
Old   April 19, 2006, 14:42
Default Re: How to know which pdf file contain the right i
Robin
From Acrobat Reader, choose Search and pick the directory containing your PDF files. You don't need to open all the files.
[swak4Foam] swak4foam building problem GGerber OpenFOAM Community Contributions 54 April 24, 2015 17:02
Installation of OpenFOAM-1.6 on Ubuntu 9.10 marval OpenFOAM Installation 2 March 17, 2010 09:33
Problem installing on Ubuntu 9.10 -> 'Cannot open : No such file or directory' mfiandor OpenFOAM Installation 2 January 25, 2010 10:50
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 11:23
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 15:00
