January 30, 2020, 10:13 |
Pressure spectra - FFT for pressure field
Jiri
Rep Power: 13 |
Hi there,
when doing transient analysis in CFX, can CFD Post make FFT (or DFT) of pressure for each node on a surface in order that I could obtain pressure contour in frequency domain? How to figure this out in CFX / CFD Post ? |
January 30, 2020, 17:36 |
Rep Power: 144 |
I would export the data and do the FFT in an external package like matlab or python.
January 31, 2020, 03:46 |
Jiri
Rep Power: 13 |
Thank you for the answer, Glenn. Ok, but can such data (any external data basically) be visualized in CFD Post? I guess only via import-> import surface, line or point data?
If so, it is just "point" data. But how to proceed to get a surface contour? Well I managed to do that by "User surface". But you must include "face connectivity" otherwise you obtain just point data. But is there any similar way to import spatial data? Spatial data of my variable which could be visualized for example by cross-section plane? The surface data was figured out by "User surface", but an analogous way is not possible for spatial distribution of a user defined variable. Last edited by Jiricbeng; January 31, 2020 at 06:44. |
January 31, 2020, 06:39 |
Rep Power: 144 |
You can't get other data into CFD-Post easily. You would have to export the position data as well so you could plot this externally.
February 3, 2020, 04:01 |
Jiri
Rep Power: 13 |
And is there any "uneasy" way to do that?
February 3, 2020, 05:36 |
Rep Power: 144 |
You can get data into CFD-Post via the data import function in solver manager. I am not sure I got the name exactly right as I am not at work at the moment. You could write the data in a format it accepts (such as CGNS) and then you can get it into CFD-Post. But this is very "uneasy"
Foam::error::PrintStack | almir | OpenFOAM Running, Solving & CFD | 92 | May 21, 2024 08:56 |
Another discussion on velocity-pressure coupling | toodles | Main CFD Forum | 16 | January 6, 2018 15:45 |
Ocean pressure field problem | luisao | FLUENT | 1 | May 11, 2017 11:20 |
static vs. total pressure | auf dem feld | FLUENT | 17 | February 26, 2016 14:04 |
Problem with rhoSimpleFoam | matteo_gautero | OpenFOAM Running, Solving & CFD | 0 | February 28, 2008 07:51 |
