eddy viscosity
Old   April 3, 2006, 17:03
Default eddy viscosity
Mike
Hi all,
I have one more question. The cfx manual states that eddy viscosity should be of the order of 1000 times the dynamic viscosity for a fully turbulent flow. I am checking the values of eddy viscosity in the domain and it varies 0-300 times to dynamic viscosity. How does this affect the results? So if most part of the domain is not fully turbulent what happens? any help would be very much appreciated.
Mike
Old   April 4, 2006, 14:12
Default Re: eddy viscosity
Robin
Hi Mike,
It's hard to say exactly what the effect will be. Most Turbulence models are created by making some simplifying assumptions about the Reynolds averaged flow. These assumptions may no longer apply.
See how your results compare when you run laminar flow. You could also try the SST transition model, although I suggest reviewing the documentation carefully to ensure its applicability as well.
Regards, Robin
Boussinesq eddy viscosity assumption siw Main CFD Forum 2 February 17, 2011 13:30
Eddy Viscosity Transport Model Jade M Main CFD Forum 0 April 21, 2010 15:17
Link between eddy viscosity and subgrid-scale turbulent viscosity in LES Marvin Main CFD Forum 6 December 4, 2009 12:08
Question about eddy viscosity ratio limit Piti CFX 2 January 17, 2008 17:49
Vertical eddy viscosity in channal flow? Liu Main CFD Forum 0 June 15, 2004 22:07
