properties at specified location in Expression
Old   April 3, 2006, 16:22
Default properties at specified location in Expression
Atit
I'd like to set 'U2' as the average velocity at y=50 m, but y=50m is not the inlet or outlet of the domain, how can I refer to the average velocity at y=50 m in the domain?
I also want to refer my variable in Expression Editor to the velocity in 'theta' component, such as the angular velocity on the plane y=50 m at radius=4 m, how can I do this?
Thank you very much for your kind consideration.
Atit
How to install CGNS under windows xp? lzgwhy Main CFD Forum 1 January 11, 2011 19:44
CGNS lib and Fortran compiler manaliac Main CFD Forum 2 November 29, 2010 07:25
Constant velocity of the material Sas CFX 15 July 13, 2010 09:56
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 21:30
Lift, Drag Vs time chart,calculations Jamesd69climber CFX 8 February 17, 2005 18:23
