January 29, 2020, 13:13 |
chosing function based on problem
SANKET BHATT
Rep Power: 7 |
I have complex tubular assembly as shown. Fluid flows from internal path, so it will push the Mandrel (green part) towards right side. Some fluid will flow annular gap between Mandrel and restriction (pink part) and then it will force piston (sky colour) on left side.
Model: k-e Fluid: Cement Inlet B.C.: 79.5 kg/sec Outlet B.C: 0 gauge pressure My question is 1) Since I want to estimate net force acting on Mandrel (green part), which function (area, area-avg, mass-flow-avg, mass-avg etc , will give me near to exact value in CFX?. I want to make it as monitor point. 2) If I want to find erosion rate by cement flow on solids, what should be approach ? Thanks. |
January 29, 2020, 16:44 |
Rep Power: 33 |
In theory, from the available variables/functions, you should use
force_x()@Boundary of Interest force_y()@Boundary of Interest force_z()@Boundary of Interest Anything else, it would be arranging/smearing the numbers to be something you expect. |
area averaged, function, mass flow average |
whats the cause of error? | immortality | OpenFOAM Running, Solving & CFD | 13 | March 24, 2021 08:15 |
Running UDF with Supercomputer | roi247 | FLUENT | 4 | October 15, 2015 14:41 |
[blockMesh] non-orthogonal faces and incorrect orientation? | nennbs | OpenFOAM Meshing & Mesh Conversion | 7 | April 17, 2013 06:42 |
is internalField(U) equivalent to zeroGradient? | immortality | OpenFOAM Running, Solving & CFD | 7 | March 29, 2013 02:27 |
Droplet Evaporation | Christian | Main CFD Forum | 2 | February 27, 2007 07:27 |
