Negative Total Fluid Mass Source - VOF
Like Tree1Likes
Old   January 29, 2020, 12:10
Default Negative Total Fluid Mass Source - VOF
Davide
marsa27 is on a distinguished road
Hi, I'm me interested to use a negative "Total Fluid Mass Source" in my VOF simulation to let out air from my mold for the glass forming. I'using a VOF omogeneous model. How I can let out only air from the wall rather than the glass, which must to touch the walls of the mold to cool down without going out too? Is necessary to use a non omogeneous VOF model? In this last case how can I calculate the correct Cd between air and glass? Is it possible set another option to avoid the specification of the Cd?
Thank you
marsa27 is offline   Reply With Quote
Old   January 29, 2020, 13:23
Gert-Jan
Gert-Jan will become famous soon enough
Can't you apply the Degassing boundary condition? This will dstinguish between air and glass
Gert-Jan is offline   Reply With Quote
Old   January 29, 2020, 16:42
Davide
No because the walls of the mold are interfaced with the solid. So I cannot use an outlet condition for these interfaces. Moreover the degassing condition requires a fluid dispersed (air dispersed in the glass) and accoriding to me it is not very correct, because I should set the diameter of fluid dispersed and the cd for the not omogenous model. Am I wrong?
Old   January 29, 2020, 18:31
How does the air and glass exist? Is the air mixed in the glass as bubbles or inclusions? Is it dissolved in the glass? Or are there clear boundaries between glass and air?
Note: I do not answer CFD questions by PM. CFD questions should be posted on the forum.
Old   January 30, 2020, 04:30
Davide
There are clear boundary between air and glass as in the Figure attached. In fact this simulation is the final forming of the glass parison in a final mold trough a air blowing form the top. Instead the air between the parison and the mold must be expeller during this blowing
Old   January 30, 2020, 05:36
In that case you should use a homogenous multiphase model with a free surface model. Have a look at the air/water tutorial example of "free surface flow over a bump" for how to set this up.
This should also make the task of working out how to expel the air easier - you just do whatever is done in the real mould to expel the air. It probably has some venting ports somewhere. So just include the vent ports as normal pressure openings or outlets and you won't have to do any special treatment with them. That is, your gas only mass sink is not required.
Old   January 30, 2020, 06:16
Davide
Unfortunately in the reality the mold is not completely hermetic, while in CFD the domains are closed. I'have already tried to use some patchs to put fictitious outlets, however when the air blow in pressure from this outlets escapes also the glass. For this reason I am intereseted to use a condition wall only for the glass and outlet for air. How can I do?
Old   January 30, 2020, 17:31
Does the air escape on the mould parting line, does the mould have lots of little air vent holes in it, or is the mould porous to air?
Old   January 30, 2020, 17:38
Davide
Exactly, but how I can simulate this situation to let to the air to escape, without that also the glass escapes?
Old   January 30, 2020, 17:47
I was asking a question, not making a statement. Which of those three air venting options is it using?
Old   January 31, 2020, 05:16
Davide
Initially I have put some holes at the opposite position of the glass while the air blowing enters from top, but after some times also the glass escapes from these when is compressed (this problem I could resolve to adjust the time duration). However in the first part of the mold, some air remains trapped, so the glass doesn' t touch the mold without colding; instead in the bottom escpaes air ad then also glass. For this reason according to me colud be correct put a conditions for all the walls of the mold as wall only for air and outlet for the air. How can I do?
Old   January 31, 2020, 06:46
I did not understand your last post.
From my knowledge of glass blowing, they put either vent ports in the mould or they use the parting plane as a vent. Is this what is happening in your case? Or is it using something else?
Old   January 31, 2020, 06:57
Davide
Yes I use some outlets with a pressure outlet, but also the glass exits from the domain. So to avoid this, I would set a wall condition only for the glass at all the walls of the mold
Old   January 31, 2020, 17:52
Let me put this bluntly - you are proposing a poor fix for a problem you should not have because you are modelling the entire thing wrong in the first place. Your questions is a classic X-Y problem (https://en.wikipedia.org/wiki/XY_problem)
You need to be using the correct multiphase model before you consider how to handle the air. You need to be using a homogenous free surface multiphase model, not a dispersed model.
Old   February 1, 2020, 05:44
Davide
In fact in the third post of this thread I have written that a dispersed fluid is wrong.. It was another person who offered me the degassing condition and I said that in my opinion it is wrong. I am using a VOF homogeneous model and my problem is that I would that only the air exits from the mold without the glass. I think I was clear. Do you know the solution for my problem? My questions are those reported in my first post... then I have attached a figure in answer to you in the 5th post that didn't understand why the air exists in my problem
Old   February 1, 2020, 05:59
I see you did say that in your first post. Sorry about missing that, looks like I overlooked that comment. My apologies.
Some ideas:
* You could use vents with normal openings in them, but at the start of the vent use a momentum source term to stop the flow with a bulk source making it only apply to the glass volume fraction.
* Quoting the documentation, Solver Modelling guide, section 7.16.3 "The phasic mass flow outlet condition is not available for homogeneous multiphase simulations" - so you can't make an outlet which does not draw a specified phase.
So at first glance it looks like the bulk source term acting on a momentum source term is the only one I can think of at the moment. You may be able to find other ways if you hunt around.
But if the vents are small in diameter, then won't the very high viscosity of the glass mean that it will not travel far into the vent? Then you don't need any special treatment.
Old   February 3, 2020, 05:20
Davide
Some ideas:
Thank you for the answers.
*As bulk source what what do you intend? Beacuse I see that there are three equation soruces: for energy, for eddy dissipation and for TKE. Instead a source for the continuity equation setting a negative massflow rate (sink) only for the air I already tried with a homogeneous model, but in reality also the glass escapes out.
*According to you, using a not homogeneous multiphase model, if in the outlet I set fluid dependent and then in the fluid values tab I set for the glass a zero massflow rate, while for the air a massflow rate>0, is correct?
Old   February 3, 2020, 05:40
Bulk sources can be applied to a momentum equation, and that is what I suggested.
You cannot define a mass source/sink to only gobble up one phase (as you have found out). There is no way I know to change this.
inhomogenous model question - I don't think so. But feel free to have a look in the documentation and try some ideas.
As I said, the only way I can think of doing this is to put a normal pressure opening in a small port and use a bulk source term on the momentum equation in the port to stop the glass phase going down the port (so the glass never gets to the opening).
Old   February 3, 2020, 06:02
Davide
Unfortunately I don't better understand how setting a bulk source for the momentum equation and what to specify.
I have set in an small patch an opening pressure condition and then in its source tab, after to have activated "bulk sources" I cannot to find the momentum equation. I attach the options that I can see with a figure.
Am I doing something wrong?
Old   February 3, 2020, 17:23
The opening is just a normal pressure opening. No special treatment at all. But in the port leading to the opening you apply a volume bulk momentum source to stop the glass phase only.
Error message: Insufficient Catalogue Size Paresh Jain CFX 33 August 16, 2024 06:09
Using PengRobinsonGas EoS with sprayFoam Jabo OpenFOAM Running, Solving & CFD 36 July 16, 2024 04:52
polynomial BC srv537 OpenFOAM Pre-Processing 4 December 3, 2016 10:07
Wrong flow in ratating domain problem Sanyo CFX 17 August 15, 2015 07:20
Water subcooled boiling Attesz CFX 7 January 5, 2013 04:32
