February 4, 2020, 07:14 |
#21 | |
Davide
Rep Power: 11 |
Excuse me, but I can't find the option to introduce the volume bulk momentum source in the patch where I set the opening condition. Where is it? Then I don't understand that value put to stop the glass phase only. Kindly can you explain in detail the steps and an example? |
February 4, 2020, 18:13 |
#22 |
Rep Power: 144 |
You can't put it on the opening. You obviously don't understand what I am saying so I have posted this picture of what I mean. Does this explain it to you?
Vent.png It shows a small vent port in the side of the cavity with a normal opening at the end. A bulk momentum source term at the start of the vent stops the glass phase from going down the port.
February 5, 2020, 07:21 |
#23 | |
Davide
Rep Power: 11 |
Pratically you propose to put some small ducts where the air can escape and internal to these ducts set a porous subdomain with a resistance that stop the glass and let to go out for the air. Is correct? |
February 5, 2020, 18:09 |
#24 |
Rep Power: 144 |
Yes, but I propose more than just some resistance. Use a source term to totally stop the glass phase. Then the air can flow through it unimpeded, but the glass will be stopped from entering. This appears to be what you are looking for.
February 6, 2020, 05:49 |
#25 | |
Davide
Rep Power: 11 |
I attached a figure with the possible options to activate. Can you suggest me the better option? thank you. |
February 6, 2020, 06:08 |
#26 |
Rep Power: 144 |
Use a general momentum source, with the source term set up to make the velocity of the glass phase zero. You can do this by using the old trick of a source term to set the velocity to a defined value. This link describes how to do it: how to set velocity in certain place in CFX5
(And it also describes how long I have been around here )
February 10, 2020, 05:05 |
#27 |
Davide
Rep Power: 11 |
Thank you. But I cannot understand how this source is valid only for the glass and not also for the air. There is not a specification on the fluid (VOF) in which to apply this source. So I fear that it stops all the fluids (both glass, both air)
February 10, 2020, 17:35 |
#28 |
Rep Power: 144 |
Have a look in the CFX documentation on bulk source terms and how it appears it can act on one phase only. See if that does what you want.
February 11, 2020, 05:59 |
#29 | |
Davide
Rep Power: 11 |
Now in the menu of the subdomain (that I attach here) CFX requires to set the X,Y,X component in [kg/(m^2*s^2)]: what value must I set to have a velocity of the glass zero? Then momentum source coefficient? Is then necessary specify for the momentum source coefficient an expression to make this coeffcient high only for glass.Vof>0? Thank you |
February 11, 2020, 18:59 |
#30 |
Rep Power: 144 |
Looking into the bulk option you are right, it does not appear to allow you to apply the source term to one phase only. You appear to be able to do it for mass fractions (so it works for multicomponent mixtures), but it does not work for volume fractions (so it does not work for multiphase models).
You might be able to do it in CCL rather than through the GUI. I have not tried that, I will leave it up to you to explore that. I don't understand why you can do it for mass fractions but not volume fractions. But it suggests that what you are proposing (a vent which works for one phase only in a homogenous multiphase model) cannot be done. In that case you may be restricted to making the holes small, so the high viscosity of glass and surface tension stops the glass phase going out the vent. Of course this is how the vents work in actual glass moulding - it is usually preferable to model what happens in the actual case anyway.
Error message: Insufficient Catalogue Size | Paresh Jain | CFX | 33 | August 16, 2024 06:09 |
Using PengRobinsonGas EoS with sprayFoam | Jabo | OpenFOAM Running, Solving & CFD | 36 | July 16, 2024 04:52 |
polynomial BC | srv537 | OpenFOAM Pre-Processing | 4 | December 3, 2016 10:07 |
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 07:20 |
Water subcooled boiling | Attesz | CFX | 7 | January 5, 2013 04:32 |
