Deposition Rate and Wall Shear
Old   January 27, 2020, 10:35
Default Deposition Rate and Wall Shear
Daniel
zacko is on a distinguished road
Hello everyone,
I have a Simulation (Domain with a Blade profile) with water droplets in a gas flow. I'm simulating with the Euler-Lagrange Model.
In Papers the Deposition Rate has been invastiagted multple times and is always plotted non-dimensional with the non-dimensional Relaxation-Time of the Particles. The Probelm that I have is, that my Data doesn't align with the Research Data (for example: Guha -Transport and Deposition of Particles).
The Deposition Rate is defined as the MassFlow of the Particle at the Wall (here a Blade) divided by the Area. I can get it via the Variable in CFD Post Water.Wall MassFlow Density. Here I use areaAve(). I can re-check the Value with the MassFlow Rate expressed in my .out-file. Both are the same. So I guess this way of calculating it, is correct.
If not, please tell me.
Furthermore I need the Wall Shear Stress to calculate the Friction Velocity for the dimensionless relaxation-time and dimensionless Deposition rate. Here I used the predefinied "Wall Shear" Variable. I calculated it via areaAve(Wall Shear)@Wall.
Btw my maxVal(Yplus) is 1.6.
Here also, is it correct? These are the only values that might be wrong. Are these correct, I need to think of other influences.
Has anyone done this before and may see my Problem in calculating these two variables ?
Thank you very much.
Daniel
zacko is offline   Reply With Quote
Natural convection in a closed domain STILL NEEDING help! Yr0gErG FLUENT 4 December 2, 2019 01:04
Water subcooled boiling Attesz CFX 7 January 5, 2013 04:32
What is wall shear stress and shear strain rate? warlocklw Main CFD Forum 2 May 21, 2012 07:16
UDF for wall slipping HFLUENT Fluent UDF and Scheme Programming 0 April 27, 2011 13:03
What is the detail definition of wall shear stress zjm FLUENT 0 January 2, 2002 08:43
