The problem about add body force(physical external forcing)using CFX
Old   January 16, 2020, 11:29
Default The problem about add body force(physical external forcing)using CFX
jinzhihui
Jinzhihui is on a distinguished road
Hi
I'm trying to add a body force to momentum source through CFX.
I have a constant body force f(fx fy 0) which Located in a specific area(such as x1<x<x2,y1<y<y2). I want to add them to the momentum equation.I have added only one direction body force(X or Y,but not all)to Subdomain Source form with User CEL function and Routine in CFX successfully.
PHP Code:
#include "cfx5ext.h"
dllexport(user_source)
SUBROUTINE USER_SOURCE (
NLOC,NRET,NARG,RET,ARGS,CRESLT,CZ,DZ,IZ,LZ,RZ)
INTEGER NLOCNRETNARG
      CHARACTER
*(4CRESLT
      REAL    RET
(1:NLOC,1:NRET), ARGS(1:NLOC,1:NARG)
INTEGER IZ(*)
CHARACTER CZ(*)*(1)
DOUBLE PRECISION DZ(*)
LOGICAL LZ(*)
REAL RZ(*)
CALL USER_SOURCE_SUB (NLOC,RET(1,1),ARGS(1,1),ARGS(1,2))
C
      CRESLT
'GOOD'
END
      SUBROUTINE USER_SOURCE_SUB
(NLOC,SOURCE,X,Y)
      DO
ILOC=1,NLOC
         SOURCE
(ILOC) = 0.0
IF (X(ILOC).GE.1.5  .AND. X(ILOC).LE.2.5  .AND.
Y(ILOC).GE.1.5 .AND. Y(ILOC).LE.2.5THEN
            SOURCE
(ILOC) =  1000000.0
         END
IF
C---------------------
END DO
C
      END
Now I need to add Fx and Fy simultaneously ,The NRET of CEL Routine is always 1 in CFX according to User CEL Function and Routines in the CFX Modeling Guide.So I tried to use two CEL Function from two different Routine,and define of the Functions as below:
(1)this work done successfully,these Functions from the same Routine.
(2)this work can't run
Unfortunately,I got error message.Notice that the Function 1 and 2 from two Routines,because i need two kinds of return Values.
1.If there are any mistakes in what I have finished(add one dirction body force)?
2.What is the reason for this mistake?
3.How to add different direction momentum source at same time?
Appreciate your response....
Jinzhihui is offline   Reply With Quote
Old   January 16, 2020, 11:38
Opaque will become famous soon enough
You have shown the UserFortran code, but not the context on how it is used.
Please show how it is accessed in the setup, i.e.
MOMENTUM SOURCE:
Option = Cartesian Components
X Component =
Y Component =
Z Component =
END
Opaque is offline   Reply With Quote
Old   January 17, 2020, 02:31
jinzhihui
MOMENTUM SOURCE:
X Component =
Y Component =
Z Component =
END
Thinks for your reply.
this UserFortran code is used to define one User Routine whose Option is User CEL Function, in CFX Pre.The Function which has three Arguments and onlu one return variavle is defined as below,for this routine structure of User CEL Functions only have one renturn variable :
So do you have some suggestions....
Old   January 17, 2020, 04:35
Gert-Jan
Gert-Jan will become famous soon enough
Are you convinced that function 2 is working properly? Did you for example try running only function 2? Or using functions 2 twice, for x and y component?
Gert-Jan is offline   Reply With Quote
Old   January 17, 2020, 05:16
jinzhihui
Yes,I have already run only function 2 for X ,for X and Y component both,It's OK.
I guess the reason for error is the two User Function for X and Y component come from two different User Routines, and CFX need to call two different User CEL Function Routines(Both of these two Routines can run independently,and the Structure of Routines same as the first Fig) .This means CFX call the Function using the same Routine(only one) for x and y component, It can run.
Old   January 17, 2020, 06:14
Gert-Jan
I would like know what ANSYS says........
Old   January 19, 2020, 23:45
jinzhihui
ANSYS prompt this error message
I don't get what you mean....
Old   January 20, 2020, 04:16
Gert-Jan
I mean the ANSYS support help desk
body force, cel function, cfx, momentum sources
CGNS Compiling Diego Main CFD Forum 17 December 21, 2014 02:40
modeling a floating body in cfx neda2014 CFX 9 October 14, 2014 05:53
CFX parallel hp MPI problem fluidmechanics CFX 5 June 19, 2013 20:05
CFX pressure in Simulations problem nasdak CFX 1 April 14, 2010 14:22
CFX 4.4 installation problem Pandu Sattvika CFX 1 December 1, 2001 05:07
