January 16, 2020, 03:11 |
Memory Allocation Factor Setup on Cluster
Mikael
Rep Power: 7 |
Hi everyone,
I was working on a transient analysis on my local computer. At first, I got insufficient memory allocated error. I increased the memory allocation factor and problem is resolved. Now, I want to work on cluster. I uploaded .def file to the cluster server and started my analysis. Again, I got the same error. Due to the reason that memory allocation factor is adjused under solution menu not under setup menu, I don't know how to deal with this error. My question is that how can I define memory allocation factor to the .def file. Thanks for your helps. |
January 16, 2020, 10:34 |
Rep Power: 33 |
cfx5solve -help
will list all the available command. Check for memory related commands for step in the process, i.e. different controls for interpolation, partitioner and solution |
January 16, 2020, 18:11 |
Svetlana Tkachenko
Rep Power: 15 |
In the CFX-Solver window after changing the memory allocation factor, click the "Save settings" button at the bottom of the dialog. This updates your .def file, which you can then upload to the cluster (together with your .cfx file) to make sure that this setting is utilized. Is this sufficient without the need to edit your job script?
To specify this value in the job script, I believe you need to add "-s 1.2" to your cfx5solve command line, replacing 1.2 with your desired memory allocation factor. Does this work for you? Thanks |
January 17, 2020, 00:36 |
Mikael
Rep Power: 7 |
Thank you Opaque
January 17, 2020, 00:44 |
Mikael
Rep Power: 7 |
Hello Svetlana, actually I've tried save settings button but it did'nt work for me. Then I found how to change solution settings in setup menu which allows me to embed the memory allocation factor into the .def file. In CFX setup interface, there is a simulation control setup at the bottom. When you right-click it and insert execution control, you could change solver settings like memory allocation factor. Thanks for your help.
January 17, 2020, 00:51 |
Svetlana Tkachenko
Rep Power: 15 |
I see. Are you running it from outside Workbench? Is it working now?
January 17, 2020, 02:18 |
Mikael
Rep Power: 7 |
Yes I am running it from cluster (pbs works). It is running without any problem.
October 18, 2021, 15:51 |
Mekuannint
Rep Power: 10 |
on the batch script, it should be -sizepar 1.05
cfx, clusters, hpc cluster, memory allocation factor |
Workbench 16.0 - Memory Allocation Factor | 196235 | CFX | 3 | August 11, 2016 03:05 |
Run-time memory allocation error | aniseh | CFX | 1 | November 19, 2014 05:32 |
Run-time memory allocation error | akalopsis | CFX | 0 | November 17, 2014 18:17 |
about numeca harmonic method Memory allocation failed | uqzcpo | Fidelity CFD | 2 | October 7, 2011 23:10 |
Memory allocation problem | shhe | CFX | 4 | January 7, 2004 00:00 |
