Output Parameter on workbench, average of last 50 Iterations |
January 7, 2020, 11:20 |
Sebastian K
Rep Power: 6 |
I´ve got a big problem. I´m working with TurboGrid and CFD Simlution in the Workbench. My Problem is: my fliud is very turbulent and the solution after x Iterations is not really converting. My idea: take the arithmetic average of the last (e.g.) 50 Iteration to have a value to work with. how I tried it: CFX\SETUP (pre): -I created a Variable "VARpsi". -I created a monitor point "MPpsi" of my variable "psi" in SOLVER\OUTPUT CONTROL\MONITOR. -In this Monitor Point it shows me the Monitor Statictics of a "Moving Interval" about 50 "Iterations". The monitor Point works without Problems. -I created an expression "avepsi" with the Definition : probe(Expression Value.Arithmetic Average) @MPpsi -In the Geometry "R1" (where I want to have my average Value of the last 50 Iterations) I add to my Varibale "VARpsi" the Expression "avepsi" CFX\RESULTS (post): -Now I need the Output Paramameter: I created an expression "averagePsi" with the Definition: VARpsi @R1. R1 is here the Geometry where I want to have my value. -In the next step I set the expression "averagePsi" as Output Parameter in the Workbench. after the Simulation the Parameter exists but without a value. Do someone have some thoughts about this? I´m thankfull for every help! with regards Sebastian Last edited by eSKa; January 8, 2020 at 04:10. |
January 8, 2020, 10:00 |
urosgrivc
Rep Power: 12 |
average of the last 50 Iterations...
If you want moving average MA50 of any expression or variable you can set it up in CFX-solver manager in solution monitors so you can monitor it while the computation is going on. |
January 9, 2020, 07:32 |
solution
Sebastian K
Rep Power: 6 |
Hi, thank you.
I found the problem now. In the POST there was a problem. Ansys CFD couldt recognize the Variable VARPsi. in the POST: for the first: I defined a Variable "VARpsi". in the Expression averagePsi: instead of "VARpsi @R1 I defined it as "ave(VARpsi)@R1. To take the average is here no problem because VARpsi is an average value. Now it works because of a little trick, nbut I dont know why |
April 12, 2022, 05:11 |
Steffen Lehmann
Rep Power: 4 |
I want to do exactly the same as you did. Unfortunately, I do not understand how you set up everything. Could you explain again a little bit better? Thank you in advance |
April 12, 2022, 14:13 |
Sebastian K
Rep Power: 6 |
Hi.
I completed my work 2 years ago. I have only this describtion. You have to follow every step. I think its written clearly. If u couldn t understand a step pls ask. |
April 14, 2022, 02:59 |
Steffen Lehmann
Rep Power: 4 |
Thanks for your reply :-)
In my case I have an automated workflow for a parameter optimization. Since the pressure loss (dp from inlet to outlet) is pulsating I want to have the average pressure loss of the last 50 iterations. Is this summary of the workflow correct? CFX\SETUP (pre): 1.1) Create a Variable "VARpsi" 1.2) Create a monitor point "MPpsi" of the variable "psi" 1.3) Set for this Monitor Point the Monitor Statictics: "Moving Interval about 50 "Iterations". 1.4) Create the expression "avepsi" with the Definition: probe(Expression Value.Arithmetic Average) @MPpsi 1.5) In the Geometry "R1" (where I want to have my average Value of the last 50 Iterations) I add to the varibale "VARpsi" the expression "avepsi" CFX\RESULTS (post): 2.1) Define a Variable "VARpsi". 2.2) Create an expression "averagePsi" with the Definition: ave(VARpsi)@R1 2.3) Set "averagePsi" as output parameter What I do not understand is: -Step 1.1): Which definition has this variable? -How do you link in CFX-Pre an expression and the variable? -What is your geometry R1. Is it the outlet plane? -What do you mean with the step 1.5). Could you explain it better? -Step 2.1) is also not clear. What is the definition of this variable? With which expression do you link this variable? |
May 10, 2022, 09:20 |
Steffen Lehmann
Rep Power: 4 |
Is there any other help available to solve this issue?
May 10, 2022, 18:21 |
Rep Power: 144 |
The description you quote does not look very helpful to me. I would ignore it. It is for a steady state run and yours is transient for a start.
It is quite simple to do a running average of the pressure drop. Set a monitor point, option=expression, expression value=(whatever, maybe areaAve(p)@inlet-areaAve(p)@outlet), and set monitor statistics=on, Time=(averaging time you want). To make this variable accessible in workbench you find the variable in CFD-Post and set it as an output parameter.
May 11, 2022, 04:01 |
#9 |
Steffen Lehmann
Rep Power: 4 |
Hi Glenn
Thanks for your fast reply. I did it exactly as you described in CFX-Pre. Unfortunately, I can not find this variable/expression in CFD-Post. The Monitor Statistics appear in the CFX-Solver-Manager-Monitor: dp(Arithemtic Average). But afterwards in CFD-Post I can not find this Monitor Point Statistics any more. How and where can I find this Monitor Point? |
y+ and u+ values with low-Re RANS turbulence models: utility + testcase | florian_krause | OpenFOAM | 114 | August 23, 2023 06:37 |
Extrusion with OpenFoam problem No. Iterations 0 | Lord Kelvin | OpenFOAM Running, Solving & CFD | 8 | March 28, 2016 12:08 |
Micro Scale Pore, icoFoam | gooya_kabir | OpenFOAM Running, Solving & CFD | 2 | November 2, 2013 14:58 |
pimpleFoam: turbulence->correct(); is not executed when using residualControl | hfs | OpenFOAM Running, Solving & CFD | 3 | October 29, 2013 09:35 |
Error while running rhoPisoFoam.. | nileshjrane | OpenFOAM Running, Solving & CFD | 8 | August 26, 2010 13:50 |
