how to export mesh from ICEM CFD to Ansys
Old   March 21, 2006, 12:45
Default how to export mesh from ICEM CFD to Ansys
siv
Hello everone, I generated one mesh in ICEM CFD and exported to Ansys. In Ansys it shows only nodes and says no elements present. Any idea about the error?? Thank you.
Old   March 21, 2006, 14:01
Default Re: how to export mesh from ICEM CFD to Ansys
Chebeba
Please provide some more detail: - In what format did you export? - To CFX or Ansys FEA? - What software versions are you using? /C
Old   March 21, 2006, 14:20
siv
hi chebeba, Thank you for your response. I am using ICEMCFD 10.0 and ANSYS 10.0. In the output tab i selected ANSYS solver and then exported the mesh. I defined some boundary conditions like type of structural analysis etc.(I tried without Boundary conditions too.)
In ICEM tutorials i found one option to select ANSYS solver from Settings. But i didnt find that option in ICEM Settings Menu. Thatsy i chose output tab for exporting mesh.
Old   March 21, 2006, 14:54
Chebeba
The solver option is located under Settings > Solver.
If you can't find it, it could be because you have the wrong product settings. Go to Product > Settings and select Default, then look for the solver option again.
/C
Old   March 21, 2006, 14:59
Chebeba
Oh, and since you're posting on the CFX forum, if you want to import in CFX, you should NOT use Ansys as solver, that is for the Ansys FEA stuff. For CFX you should use Ansys CFX under the Output Tab. /C
Old   March 21, 2006, 17:16
siv
i know for CFX. i have been working since long time. But ANSYS FEA is new for me.I tried with default product settings but didn´t work. May i need separate license for that. I´ll check with ICEM support
Old   March 21, 2006, 21:00
jemteo
sorry to steal your post. but would like to know if it is possible to output CFX results to ABAQUS?
Old   March 21, 2006, 21:03
TB
Hi... If you're using ICEM10, the output solver should be ANSYS CFX. For other versions, the output solver name is CFX5 (without ANSYS in front). I assume you have checked your mesh and the errors (if any) have been cleared off.
Old   March 22, 2006, 06:07
siv
Hello All, I am asking the solution for ANSYS FEA software not for ANSYS CFX.
Old   March 22, 2006, 10:02
myron
There are some minimum things you need to do. 1. Output > Select Solver > Ansys 2. Open the Parameters tab/icon and define any of the element types, what you want to output, etc. 3. Open the Boundary Conditions tab/icon and define any that you want. 4. Now Write Output for Ansys.
The minimum would be simple Select Solver > Ansys - then open the Parameters and Apply/OK - then Write Output. This will give you the default output.
Old   March 23, 2006, 09:19
  #11
siv
I got the solution. thank you for your response. but i couldn´t find voulme elements in ANSYS. It shows only area mesh.
Learn ANSYS ICEM CFD easy_astronaut ANSYS 2 December 15, 2013 16:34
help, ICEM mesh export to ANSYS Fred CFX 3 June 28, 2007 14:51
ANSYS ICEM CFD Mesh to Gambit Simon Bergström FLUENT 0 January 19, 2007 12:53
How to extrude 2D Mesh in ICEM CFD? VSB CFX 7 December 27, 2006 12:58
ANSYS ICEM CFD smoothing mesh corner chamfered Hans CFX 4 January 26, 2006 17:00
