Defining Massflow rate at an angle
Old   March 21, 2006, 04:42
Default Defining Massflow rate at an angle
vis
Hello, How can I define mass flow rate at angle to inlet instead of normal to boundary condition. I have seen manulas about flow direction option but little confusion. The flow should enter the domain at angle with specific mass flow rate. Could any one help. Thank you.
Old   March 21, 2006, 07:47
Default Re: Defining Massflow rate at an angle
vis
i solved my problem
Old   April 28, 2021, 08:50
venu
Venu Angirekula is on a distinguished road
Hii Vis,
Please share the solution for massflow with specifed angle
Regards,
Venu
Venu Angirekula is offline   Reply With Quote
Old   April 28, 2021, 11:50
Opaque will become famous soon enough
Either I am confused, or the original submitter did not express the question properly.
Mass flow by definition is the area integral of V.N; therefore, it is not even a valid question.
What is your goal? Perhaps someone in the forum can help sort it out.
If you want to specify the mass flow and the direction of the flow, it implies you are specifying the velocity normal component implicitly
Hope the above helps,
Note: I do not answer CFD questions by PM. CFD questions should be posted on the forum.
Opaque is offline   Reply With Quote
[Netgen] Import netgen mesh to OpenFOAM hsieh OpenFOAM Meshing & Mesh Conversion 32 September 13, 2011 06:50
Pressure Drop and Massflow rate issue M Siemens 4 February 13, 2008 10:12
massflow rate specification vinse FLUENT 1 November 2, 2007 16:38
Specified angle flow rate measurement in a pipe. Sarala Siemens 0 June 17, 2006 22:49
about the massflow rate boundary condition whitemelon FLUENT 0 June 3, 2006 06:44
