December 9, 2019, 23:01 |
D32 in Expressions-Bubble Coalescence Model
Taylor Long
Rep Power: 8 |
Dear All,
I want to use my own bubble coalescence model in CFX to simulate the bubbly flow inside bubble column reactors. When I generate the Bubble Reynolds Number term where i want to use the built-in variable, D32(Averaged Sauter Mean Particle Diameter) and implement the related coalescence rate into the system. Error: The variable 'Averaged Sauter Mean Particle Diameter' referenced by parameter 'Coalescence Rate' in object '/FLOW:Flow Analysis 1/DOMAINefault Domain/MULTIPHASE MODELS/POLYDISPERSED FLUID:Polydispersed Fluid 1/COALESCENCE MODEL' does not have a required particle prefix. thus, i added the phase prefix: AIR. Averaged Sauter Mean Particle Diameter. the error turns to: The variable 'Averaged Sauter Mean Particle Diameter' referenced by parameter 'Coalescence Rate' in object '/FLOW:Flow Analysis 1/DOMAINefault Domain/MULTIPHASE MODELS/POLYDISPERSED FLUID:Polydispersed Fluid 1/COALESCENCE MODEL' is not allowed to have a phase prefix. it seems like i need a particle prefix instead of a phase prefix. Because it is gas-liquid two-phase flow, if i want to use built-in d32, what can i do? i also tried 'Mean Particle Diameter' with phase prefix, it works. Can anybody give me some suggestions? Many thanks! |
bubble coalescence, cfx, sauter mean diameter |
Use of k-epsilon and k-omega Models | Jade M | Main CFD Forum | 40 | January 27, 2023 08:18 |
Superlinear speedup in OpenFOAM 13 | msrinath80 | OpenFOAM Running, Solving & CFD | 18 | March 3, 2015 06:36 |
The selection of model to solve a bubble rise in Fluent | Xilaf | Fluent Multiphase | 9 | December 4, 2013 01:01 |
Bubble size for eulerian model | thecfduser | FLUENT | 1 | April 28, 2010 12:09 |
Coalescence model gives too big drops | Ossi | Siemens | 3 | April 29, 2002 04:31 |
