about CFX-mesh, help me please.
Old   March 10, 2006, 01:36
Default about CFX-mesh, help me please.
erick
Dear friends,
I made my model with Workbench and use CFX-mesh to generate mesn.
My model is a cylinder with two open-ends as Outlets and a hole in the middle as Inlet. The length of cylinder is 14.7 mm, diameter 2.8 mm, diameter of the hole is 1.4 mm. The fluid is compressed air.
Which settings in CFX-mesh are important to my mesh?
Thank you in advance.
Erick.
Old   March 13, 2006, 13:53
Default Re: about CFX-mesh, help me please.
TobiasZ
haven't used CFX-mesh for a while, since now using ICEM, but I think to remember u need a global maximum mesh size and perhaps some inflation at the surfaces. The size will depend on the characteristic of the flow. If you expect high gradients, you need mesh refinement - especially at the inlet. Hope this helps a bit further.
TobiasZ
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 09:54
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation tommymoose ANSYS Meshing & Geometry 48 April 15, 2013 05:24
CFX Mesh Deformation problem Silmaril CFX 7 October 19, 2010 11:00
Mesh from ICEM CFD to CFX ! Error ! Why ? Thanks ! Vu Trinh Tuan CFX 11 March 28, 2005 20:04
importing mesh from ICEM CFD into CFX 5 Jay CFX 2 November 12, 2002 14:46
