Getting .def file from .cfx5 in batch processing |
December 5, 2019, 06:36 |
Arvind
Rep Power: 10 |
I am using the command 'cfx5pre.exe -batch trial1.pre' for getting the .def file from command line.
However i am not getting any .def file generated. even running with GUI i can see the .def file is generated but not saving it. Although the last line of the .pre file shows : ' >writeCaseFile filename=C:/Users/Tapas/Desktop/Tapas/test_command/trial1.def,\ operation=write def file > update ' I feel this line is not executed, is there something i am doing wrong? |
December 5, 2019, 15:39 |
Rep Power: 144 |
This sounds like routine debugging. Load up CFX-Pre, and load the pre file one line at a time to see where it starts failing.
OpenFoam "Permission denied" and "command not found" problems. | iyidaniel@yahoo.co.uk | OpenFOAM Running, Solving & CFD | 11 | January 2, 2018 06:47 |
polynomial BC | srv537 | OpenFOAM Pre-Processing | 4 | December 3, 2016 09:07 |
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch | gschaider | OpenFOAM Installation | 225 | August 25, 2015 19:43 |
"parabolicVelocity" in OpenFoam 2.1.0 ? | sawyer86 | OpenFOAM Running, Solving & CFD | 21 | February 7, 2012 11:44 |
OpenFOAM on MinGW crosscompiler hosted on Linux | allenzhao | OpenFOAM Installation | 127 | January 30, 2009 19:08 |
