November 29, 2019, 22:17 |
where finding :quench flux?
Rep Power: 12 |
simulating a vertical Subcooled Boiling and the wall boiling model was used.when i do the postprocessing,i cannot find the quench flux and convective flux?where i can find? if using fluent do the simulation,i can see the three part heat flux. cfx can not show the three part heat flux? thanks for any help!
November 30, 2019, 04:19 |
Zhipeng Yao
Rep Power: 7 |
I found following relationships:
'Liquid.Wall Heat Flux'='Vapour|Liquid.Heat Flux to Liquid'≠0, 'Vapour|Liquid.Heat Flux to Liquid'+’Vapour|Liquid.Heat Flux to Vapour'='Wall Heat Flux', 'Vapor.Wall Heat Flux'=0, 'Vapour|Liquid.Heat Flux to Vapour'≠0. I think that Qq and Qc are included in 'Vapour|Liquid.Heat Flux to Liquid', and they may need to be represented by CEL. I am also confused about this, and hope to get a solution too. Last edited by Z.P. Yao; November 30, 2019 at 10:13. |
Radiation in semi-transparent media with surface-to-surface model? | mpeppels | CFX | 11 | August 22, 2019 07:30 |
My radial inflow turbine | Abo Anas | CFX | 27 | May 11, 2018 01:44 |
How to use "translation" in solidBodyMotionFunction in OpenFOAM | rupesh_w | OpenFOAM Running, Solving & CFD | 5 | August 16, 2016 04:27 |
Udf for moving heat flux in 2D cylindrical geometry | devia21 | Fluent UDF and Scheme Programming | 0 | April 20, 2015 00:27 |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 06:28 |
