March 5, 2006, 20:47 |
high resolution or upwind
Dear Sir,
I want to simulate compressible in a pipe with CFX 10.0. Which way is better, high resolution or upwind? Thank you in advace |
March 5, 2006, 21:39 |
Re: high resolution or upwind
Upwind is only 1st order accurate. Use high resolution if accuracy is needed.
March 9, 2006, 00:09 |
use upwind to test the system, see the flow pattern first. Then use high reslution with the upwind.def file as initial value
High Resolution (CFX) vs 2nd Order Upwind (Fluent) | gravis | ANSYS | 3 | March 24, 2011 02:43 |
about upwind and high resolution | Eric | CFX | 1 | December 30, 2006 06:56 |
upwind vs high resolution | Richard | CFX | 3 | February 20, 2006 06:35 |
Multicomponent fluid | Andrea | CFX | 2 | October 11, 2004 05:12 |
Upwind vs High Resolution | Liwau | CFX | 2 | April 20, 2004 11:49 |
