March 5, 2006, 09:13 |
ICEM Prism mesh assertion?
Hi all! Has anyone here tried to do prisms in ICEM CFD 10.0.1 with a surface that has mixed quads and triangles? It seems no matter what I do (tried different hybrid mesh types, blocking, running prisms before/after volumes) I get a crash in the prism mesher after Initializing Heights:
Assertion failed: fc->ops[2] == v3, file compute_marching_dir.C, line 237 I've been through my geometry with a fine tooth comb, all curves and surfaces match perfectly, all normals are OK, etc. As long as I stay tri only I can run the prisms fine, but not with quads /C |
March 5, 2006, 11:24 |
Re: ICEM Prism mesh assertion?
Have you tried put prisms on quads and triangles separately and merge them together?
March 5, 2006, 11:51 |
Interesting suggestion ;-). But how? I go "Select Parts for Prism Layer". If a part has a mixed quad/tri surface mesh, I don't see where I can select only one element type?
Gambit problems | Althea | FLUENT | 22 | January 4, 2017 04:19 |
Prism mesh | Mohankumarg12 | ANSYS Meshing & Geometry | 7 | July 27, 2011 17:10 |
ICEM CFD Prism Mesh Generation Problem with Ansys 12.0 & windows 7 OS | kh_thakor | ANSYS Meshing & Geometry | 1 | February 1, 2011 21:22 |
ICEM 10 mesh question | DAK565656 | CFX | 6 | May 8, 2007 13:16 |
How to control Minximum mesh space? | hung | FLUENT | 7 | April 18, 2005 10:38 |
