Restatring run
Old   March 3, 2006, 09:10
Default Restatring run
Tim
Hi, i had a run that stopprd halfway through because of a disk space problem. I have a backup file (*.bak) from just before the run was terminated. i've read a previous thread on here about renaming it as a .res and using that in the command line instead of a .def. if i do this do i need to specify an initial results file? will the run continue on as if it hadn't been stopped? is there anything else i need to alter for the run to go ahead? any help would be much appreciated.. Tim
Old   March 3, 2006, 12:34
Default Re: Restatring run
siv
i dont know about renaming the .bak file but to restart your run:
cfx5solve -def filename(your definition file name) -initial abc_001.dir/30_full.bak
abc_001.dir is your result file name and inside that directory you will find your back up result file for e.g. 30 iterations.
If you start in this way it calculates from 31st iteration.
Old   March 3, 2006, 12:54
Tim
great! Thanks a million for the quick reply Tim
Parallel run in fluent for multiphase flow apurv FLUENT 2 August 3, 2011 20:44
Batch Run with Initial values file krrishcfd CFX 1 July 28, 2011 03:35
First Parallel Run - need some help Gian Maria OpenFOAM 3 June 17, 2011 13:08
How to run and save tranisent case on Cray XD1 Leon FLUENT 0 October 3, 2006 22:59
Windows 64-bit, Distributed Parallel Run Issues... Erich CFX 3 March 28, 2006 17:36
